Phoenix gold amps
Username: Jmloughrey
Farmington, CT
Post Number: 998
Well, seems to me like getting one of the phoenix gold Xenon amps is my best bet seeing as my sub is 600 RMS dual 2 ohm...i'm not too comfortable with running an amp at 1 ohm....also i dont think i should bridge a 2 channel amp with an orion HCCA 12" sub...
My ionly other really good option would be to get a used JL 500/1 amp....
so what should i do...Phoenix gold Xenon 600.1 brand new for like 280
or
JL 500/1 used for like 340....
Farmington, CT
Post Number: 999
http://www.audiodiscounters.com/catalog.php?view=page&qtype=Amplifiers&qvendor=V isonik&qproduct=V2118&qcategory=Car+Audio
any good? never dealt with visonik amps...
I'd get the Xenon...the Xenon amps are guaranteed cea compliant just like the JL audio amps. You get more power from the Xenon and its cheaper and basically same as the JL. If it were me id go w/ the xenon. Also, ive heard realy good things about those amps.
Username: Nnnnick_b
Nc Usa
Post Number: 267
or a kicker kx 600.1 for 280 on ebay, new.
Farmington, CT
Post Number: 1000
thats 600 x 1 @ 1 ohm...
Username: Nnnnick_b
Nc Usa
Post Number: 268
no it runs 600 at 2 ohm.
Farmington, CT
Post Number: 1001
still does me no good though, my sub is dual 2 ohm...
Username: Nnnnick_b
Nc Usa
Post Number: 269
opps didnt see dvc 2ohm, srry. so u want to run 600 at 4 ohms. A kx1200.1, jbl bp1200.1 will do that. I guess the Phoenix gold Xenon 600.1 is the best option.
Farmington, CT
Post Number: 1002
i was actually looking at the JBL GTO601.1 amp...puts out 425rms @ 4 ohms...and i know this would be a clean 425 rms...i'm thinking that the xenon may only put out closer to like 500rms if i'm lucky...so i figure for the extra like 50 bucks would it be worth it...
