Question on hooking up subs
Username: Bootykang
Post Number: 19
Hey wats up. I have an extreme 500 watt mono amp and two 12 inch 250 rms extreme subs. Should i bridge these speakers or run each sub by its self.
Username: Byrumjr
Post Number: 117
If the amp is mono there is nothing to bridge. The extreme 500 watt mono amp is most likely the max watts. The two 12 inch 250 rms extreme subs, if they are single 4ohms each you can wire them at 2 or 8 ohms. If the extreme 500 watt mono amp is 2 ohms stable it will work. You might think about just hooking up one sub to the amp.
I have a 2002 Subaru WRX and hooked up 2 10inch rockford fosgate subwoofers in the trunk with a 2400watt amp. Now i was to put 6 by 9's in there so i can here the music behind the car too. Do i need to adjust the gain? If so how do i adjust it? Is there a special way of hooking the 6 by 9's to the system?
Username: Solacedagony
New Jersey US
Post Number: 307
You need to run those 6x9s off your HU amp or get a specific amp for those 6x9s. Can't run them off your more than likely class D amp.
