Jamboree Unregistered guest | I had an earlier post and w/ some help was going to run the PPI pcx-4125, but out of the blue I got this amp for free, Kicker zx460. http://www.crutchfield.com/I-rcrwccar/cgi-bin/prodview.asp?i=206ZX460 Is this an alright amp if this is what I got: Car: '94 Accord Fronts (6 1/2): 60.5cs Infinity Kappas , 90 rms tweeters , 50 rms Rears (6x9): 9602i Infinity Reference , 100 rms Sub (12"): 1 JL Audio 12W3v2 , 300 rms If it is which amp would be good to run the sub, b/c I was thinking of the Kicker zr240? And if it won't do I'll end up sticking w/ the PPI's and get it for $400 Thanks again for advice |
Silver Member Username: Taylor17Kopperl, Texas Post Number: 967 Registered: Jan-05 | The Kicker should work. How did you get that amp for free? |
Gold Member Username: CarguyPost Number: 1906 Registered: Nov-04 | As long as it wasn't the "five" finger method then it's okay. As far as amp comparison, PPI's would've been far better, not only in SQ, but also in power. The Kicker is only 30w rms. Barely beating out your stock radio, which is 18w-20w rms average. So yes you will see some improvement, but not really worth the trouble of getting power wire kit, spending time installing or paying someone. |
Silver Member Username: Taylor17Kopperl, Texas Post Number: 975 Registered: Jan-05 | Lol. |
Silver Member Username: FishyTamarac, FL USA Post Number: 651 Registered: Sep-04 | Just bridge the thing into your kappas for 2x120 and run your 6x9's off the h/u for rear fill. You'll lose some midbass but will make up for it in vastly improved imaging. Equally powered rear 6x9's will destroy that for you. -Fishy |
Jamboree Unregistered guest | When I went to LA over the weekend I got lucky b/c my cousin just upgraded his system so he gave me these for free. |
