UTP Unregistered guest | I am about to hook up my subs to my amp, but right now I dont have good speaker wire, I have 18 gauge speaker wire, is that good or no to hook up my subs to my amp? |
jonze Unregistered guest | good for now. lol. |
UTP Unregistered guest | What gauge should I use? |
Joey Y Unregistered guest | at least 14gauge. I prefer 12 myself. |
Bronze Member Username: InvictuzSeattle, Wa Usa Post Number: 32 Registered: Jan-05 | 12 gauge is ideal, particularly if you have a quality high watt amp...14 gauge will work if using a smaller amp with a shorter distance between amp and subs. |
Silver Member Username: FishyTamarac, FL USA Post Number: 656 Registered: Sep-04 | 18 gauge won't hurt nothin. It'll just reduce power output slightly. You won't even notice the difference(except in your mind) if you go 12 gauge. I you want to get technical check this chart: http://www.tweeter.com/product/index.jsp?productId=1843714&cp=1124288.1124550.11 24487&page=2&doVSearch=no&pageBucket=0&sublevel=2&parentPage=family 18 gauge wire has a lil under 4 times the resistance per length as 12 gauge. If you have say 5 ft of speaker wire you'll have about 25 milliohms(.025 ohms) more resistance with the 18 gauge which doesn't translate to an audible SPL loss unless you're running a poopload of power. If you've got 500 watts on a 4 ohm sub you're in effect only losing about 1 watt. I don't think too many people here(even Jonathan) could tell the difference between 499 and 500 watt amps(tho Isaac might if they were PPI's). :P I run 12 gauge mainly because it looks better. ![]() -Fishy |
Silver Member Username: FishyTamarac, FL USA Post Number: 657 Registered: Sep-04 | [edit]duh "I you want to get technical..." should read "If you want..." |
Silver Member Username: FishyTamarac, FL USA Post Number: 658 Registered: Sep-04 | [edit]double duh My calculations were for 5 feet of speaker total(2.5 ft actually). You'd lose about 2 watts with 5 ft if anyone cares. ![]() -Fishy |
UTP Unregistered guest | Aight then, I gonna buy some 12 gauge then. |
