OK! So i have a 12" Audiobahn flame excurtion AW121T. My amplifier is a phoenix gold xs2500, its only 1000W, the sub is 1100W, I feel its not getting enough power. I also have an Ultralinear UL2200D amp which is 400W. Is there a way I can connect both to the sub without seriously injuring it?
Ryan, you are not under powering the subs. You talk like 1000w is nothing. Let met tell you, 300w rms of real power is enough to shake the trunk/mirrors and windows in your car. Chances are, if 1000w is not enough power, then your amp is not putting out real numbers. Try listening to a great 400w amp. It will sound louder than 1000w cheap ones. For your 2nd question, you can not combine 1000w amp with 400w amp.
