Could a 250A alt power (3) JL1000/1s with (2)yellowtops and caps
could a 250A alt power 3 1000/1 amps with the help of (2) yellow tops and a batcap equal to 100F .. oh and also there would be a 300/4 amp hooked up
Username: Invain
Michigan United States
Post Number: 376
I don't know if a 250 a alt would power 2 1000/1 amps let a lone three. Your gonna need more I say.
Username: Slap_johnson
Arizona
Post Number: 127
i say thats plenty, all depends on the vehicle though
1000/1 needs 100A according to JL
.... also the car is a escalade
...and since its got a 100F batcap and 2 bateries i figured it wudnt need the total 300A alt
also... i change my mind... it wud be 2 batteries... a xstatic 800 batcap (800 cranking amps) which is sed to be like 400 1F caps and a poweramper 15F capacitor
Username: Invain
Post Number: 377
Wellllllllll. It might be enough, I still think you could go bigger. I'm not sure though.
