A Q for my box
hello, i just made a vented enclosure for my 15" triple X. i constructed it with 3/4" MDF wood, 1 5/8" screws, and liquid nails. I painted the outside of the box and also put coat of polyurethane sealant ontop of the paint. my question is would i need to put anything on the inside of the box, like the polyurethane sealant i used on the paint??
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 317
silicon all the corners...make sure its air-tight.
Username: Rob_brown
Post Number: 49
Would you mind sharing that box design? If not could you e-mail them to me at bertobrown@aol.com. I have been meaning to call RE and ask if they have the specs for a 15 available. Thanks Robbie Brown
Username: Hdubb
Farmington, Nm Usa
Post Number: 385
use liquid nail to seal it
i already used the liquid nails, and painted and sealed the outside, i just wanted to know if i should polyuratane seal the whole inside in case it got wet. its a vented box, and if some water got in it it would mess the box up.... would it hurt to seal the whole inside?
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 144
no leave the inside as is
only thing u need to put inside is polyfill if its needed
