How to Wire Subs
Power
I need to wire 2 DVC 4 Ohm subs to an ampi need them to be at 2 ohms is there any way to do it with out adding more subs. or can i wire each sub to one channal and wire them in Parallel to get each one to a 2 Ohm load or is there some other way
Username: Krijgy
Smithfield, Virginia United states
Post Number: 13
if it is a 2 channel amp run each sub off a separate channel regularly (+ to + and - to -) then inside the box wire the subs in parallel to reduce each sub down to 2 ohms. if you have a mono channel amp i would suggest to run from the amp to the box in series which will give you 8 ohms, then inside the box run in parallel to reduse it back down to 4 ohms. then wire up an inductor that will reduce the impeedance level down to 2 ohms. enjoy.
a juggalo
best bet is with a 2-channel amp like krijgy said, on their own channels. let the amp do the work
juggalo jeff
hah whats up juggalo
