Speaker crackle
Username: Twurlurmind
Delta, Bc Canada
HI i recently got some clif designs car speakers installed. They are 6.5 2 ways witah rms handling of 60 watts. my deck puts out 19 watts rms per channel. If i turn the power up they crackle. THey do not crackle at low volume. ARe these speakers blown?
Or do I need a cleaner power source?
Username: Malby7
Post Number: 127
Well if you're just running the speakers off of the deck then that's ur problem. When you turn the deck up too high it struggles to give your speakers the correct power. And amp with greatly help this problem!
