Slot vented port width
Username: Jdub_dub
Post Number: 14
im making a ported box for 4 12's. i know the box should be the recommended box volume + port volume + driver displacement. What is the minimum height and width you would recommend for the square/rectangular port (all 4 drivers are sharing the same airspace).
Would it just be easier to build a box with tupe ports. If so where can i get the tapered ports?
please help. thanks.
