Posted on Will 2 boxes with equal cubic feet (but totally different shapes) sound the same if they have the same woofer? |
Posted on cuz i gotta build a weird shaped box to fit in an el camino.
Posted on anyone? |
Bronze Member Username: Eric77
Post Number: 23 Registered: Nov-04
Posted on As long as Its not too crazy, as in like an inch tall, i thnk you should be fine. I have always heard volume is volume. |
