I'm sure no one will believe me...but
Username: Spittin2rock
Post Number: 76
Look at the equation and tell me if you believe me or not.
HU: Pioneer DEH-P7000R
Components: SPL 6.5 2-way speakers and MA Audio Neiobium Dome Tweeters
Subs: 2 10" DVC Audiobahn AW1000Q (Ported Box)
Amp: Sony XM-4520 (45 x 2)
Hitting... this maybe hard to believe but 125.2 db and that was a cheap meter that we found and bought of the i-net. Giong tomorrow to get a better more acurate measurement. This equipment is in a 89 Honda Civic. Give your thoughts and your prediction of SPL. It's hitting hard as hell with that old tiny amp.
Help2
I believe it..
but 125.2 db isnt dick.
Ive hit 140s with 1 12 on 400 watts.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5925
that's very believable that you hit 125 with that system in a Civic.
Good job.
How does it sound for quality?
Post Number: 80
It sounds ok in quality definitely not the best. I want to go to a professional car audio shop and get it metered there. I'm not sure if the one we used was very accurate. But i still thought that was pretty good for 2 10's being pushed by a pitiful 90 watt sony amp.
Username: Jonathan_f
GA USA
Post Number: 2662
Yeah, it's pretty good for what you were pushing them with. At least you told the truth and didn't make up 200+db numbers like some people do :-).
