Need help on system plz, any suggestions
Username: Mjv817
Post Number: 26
so far this is all i got for my 1st stytem
HU-Alpine cd9835
components - infinity kappa perfects
amps- 1 Infinity Reference 7520a , and 2 mtx thunder1501's
subs- 2 re 15 trip. x
was wondering if anything else i should get to help my current system out,it seems pretty simple and at first thought i was gonna need more stuff, is there anything missing or something i should invest my money in??
Sucubus
IMO the Infinity comps are a little harsh, but
a lot of people enjoy them.
also, Id rethink the amps.
Plus, youre going to need about 500 bucks worth
of wiring and electrical system components to keep
your car from shutting off every 2 seconds.
Sweet HU for sure :-)
Username: Mjv817
Post Number: 27
my bro gots the the kappas and i like the way they sound(i can get em new for 150 so thats another reason why im gettin them), but why rethink the amps? and i have a 250 amp alternator plus my stock alternator with a yellow top battery alrdy hooked up and have the amp kits for the 2 mtx amps(maybe i should stated this stuff in my 1st post)i figured with that alternator i wouldnt have to worry about my car shutting off every 2 sec.. lol
Sucubus
lol...yeah, you should be OK as far as electrical.
I dont personally like infinity amps, but itll work.
MTXs are good amps.
Look at the eD NINe 1 before you buy em tho.
Sucubus
MTXs are good amps.
Username: Mjv817
Post Number: 28
yea ive heard about the ed nine 1 but it has less watts then mtx,but ive also heard the ednine is underrated
Sucubus
It does 1500 watts on the bench.
Username: Mjv817
Post Number: 29
o was misinformed well ill have to see which one is cheaper
Username: Mjv817
Post Number: 30
o and whats on the bench mean?? im looking at there site and it says 1200 at 1 ohm
Sucubus
Bench testing is a way to find "true RMS"
Thats the number you'll see on the
"birth sheet" that comes with Rockford and kicker
and such.
Basically bench testing uses an o scope,a dummy load(or a real speaker) and test tones
to see when clipping begins.
eD wont give you those numbers, but I know
people who have banched them to over 1500 watts.
anyhow...theyre better than anyone expected.
Sucubus
I meant "benched" not "banched"
I hate this forum...
Username: Mjv817
Post Number: 31
hah ive heard the same thing too but still wasnt sure ty for the input!
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 1081
the eD 9.1 amp can put upwards of 1600-1700 watts...being both underrated and rated at 12.5 volts, it has a potential of much higher than those numbers
Hfl, Ny Usa
Post Number: 1082
those numbers = rated numbers on site
