New member Username: DjdirtysoufTx Post Number: 1 Registered: Nov-04 | Wat up Yall im new on this site and i have some questions about my system!! feel free to answer thanks!! below is wat is in my 67 ford mustang! Okay ----------------------- Optima Yellow Top Aiwa CDCZ137 2 Power Acoustic Built N Crossover Tweeters 2 6-1/2"Alpine SPS-170A 2 12"RockfordFosgate Punch HE2 Woofers (RFP4212) RockfordFosgate Punch 801S Amplifier Subzone h-122 enclosure knukoncept Wiring Dynamat Trunk Kit ----------------------- thats what i have!! in a 67 ford mustang! okay i have those 2 12" he2's there 4ohm DVC 400wattRMS 800wattMAX EACH connected to a 2 channel 801s rockford amp im running each sub to each channel which its 2 channels and 2 subs. okay would that be perfect? Okay and the wiring is knukoncept, okay the 0 gauge is gonna be fused by the battery with a 300amp fuse and fuse holder, im running 0 gauge to my trunk cuts off at a distro block , then from the distro im runnin an 8 gauge to the amplifier, and using pair of twisted shielded rca's i think there knu koncept too, is that good wiring way i did it? subzone box h-122 is made up of 3/4in of MDF , its 1.4cubic ft each chamber and its for 2 12" woofers, so would them he2's be good for this box? and the trunk has dynamat and its an old car !! wat do you think about this system think it sounds or would sound good!!???? or wat are your oppinions on this or what? thanks!!! |
Bronze Member Username: LbecknerTulsa, Ok Usa Post Number: 45 Registered: Oct-04 | do you have an amp for your components and 6 1/2" speakers. If you did it would sound much better than without. |
Bronze Member Username: LbecknerTulsa, Ok Usa Post Number: 46 Registered: Oct-04 | Maybe a bit bigger wire for the amp? What is the recommended size? If its pushing 800W then maybe a little bigger wire wouldn't hurt. I mean geeze if you have 1/0 going to the trunk why use only 8 ga to go to the amp? Probably okay though. |
Silver Member Username: DecdeCanada Post Number: 226 Registered: Sep-04 | Dude u have a pic of your car?? I F*CKING LOVE MUSTANGS. If so post it plz. Btw, that's one wicked a*s set up u got. I woudn't touch a thing off your audio |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 5806 Registered: Dec-03 | what's under the hood? 289? 302? |
New member Username: DjdirtysoufTx Post Number: 10 Registered: Nov-04 | its a 302 boss lol jp its a 302 and yes i have a picture wats ur email ill email it to you ! what do u think about my system glass? thats all i can afford and want it to sound good |
Bronze Member Username: DjdirtysoufTx Post Number: 11 Registered: Nov-04 | then wat about a 4 gauge kit and put bass blockers on them alpines??? glass or anyone can yall help me how to set my gains on my system? |
Bronze Member Username: DjdirtysoufTx Post Number: 12 Registered: Nov-04 | this is her right here thats wat all thats in just need a paint job after that |
Help2 Unregistered guest | http://www.jlaudio.com/tutorials/Input_Sensitivity/Input_Sensitivity.html Gain setting with a multimeter. |
New member Username: ErushnakPost Number: 4 Registered: Oct-04 | The pictures were taken near the end of 2003 and its nearly 2005 and its still not painted? I would have gotten the paint before anything else myself. |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 5829 Registered: Dec-03 | ah nice shaker hood I was tempted to put a hood like that on my charger lol anyway looks like a good start on the system. you can always upgrade as ya have the funds. if the head unit doesn't have a crossover, you can use bass blockers on the alpines, sure. |
Bronze Member Username: DjdirtysoufTx Post Number: 13 Registered: Nov-04 | thanks glass i like it too!!! joe we are all different arent we?? matter a fact ive had it since 2000 and yes its gonna be 2005 and no im not in a hurry either infact i might not paint the damn thing lol jp im still in school u know im workin inside out so paint job will be last should be done by next year glass? would them bass blockers make it sound even better then it is right now? just blocks the bass and im wantin to know how to set the gains on my amp ? thanks |
