Trying to convert my system to an infinity
Username: Gearhead
I have a 97 isuzu rodeo and I put a complete lagacy system in it. Problem is it takes up WAY too much space and dosn't sound all that great. I was tryint to change over to an infinity system (much like the stock ones in jeeps). Is there a good infinity HU that will fit into a standard cd player slot? Also is it going to be possiple to mount the "stock" amp under the seat without too much trouble?
Username: Carguy
Post Number: 80
Hey Brian, you might want to go visit a stereo store and ask the guys for HU that'll fit your car. Much easier that way for you. For installing the amp under the car seat, it's possible. I have one of my amp hidden there. Just remember to wire the audio cable away from the power wire or else it'll pick up noise.
