How to Bypass cut-out unit
Username: Eamonx1
Cork, Munster Ireland
I have a set of Thomson WHP 540 U wireless headphones for use with T.V.
The unit is set to cut-out when the signal is insufficiently strong. Where I live the signal fluctuates a lot and so the unit cuts out most of the time.
How can I bypass the cut-out circuit? Would be grateful for any technical hints.
Need to Register?
Forgot Password?
Enable HTML code in message
