New member Username: Chrisg001Sussex, WI United States Post Number: 4 Registered: Aug-04 | I have been looking around for this for about a month and a half i have heard good things and bad things about subs but never can get a straight answer. Thats why i joined. I was wondering what is everyones thoughts on audiopipe, power acoustik, and SPL subwoofers. I will buy what i need to start this up but the input from others is really what i will base my purchases off of becasue all of you know whats going on becasue i haven't looked for subs in awhile things change. |
Anonymous | Power Acoustik = NO SPL = NO Audiopipe = ??? Lets start with what type of budget you have and the sound you're looking for. Also what size and how many subs do you want? |
New member Username: Chrisg001Sussex, WI United States Post Number: 5 Registered: Aug-04 | Ok I have about a $1000 to start out with if it goes over i can still afford it. The size and quantity are 2-12" subs and dual 2 ohm if possible. The amp i can match up when i find out what subs i will be getting. I already have a 1.25 cu. ft. sealed box but am willing to buy a different one if needed. I am looking for good sound quality and med to high spl/. |
New member Username: Chrisg001Sussex, WI United States Post Number: 6 Registered: Aug-04 | ANyone like visonik subwoofers |
Bronze Member Username: NickkkCharlotte, NC US Post Number: 14 Registered: Aug-04 | look into re x.x.x |
Silver Member Username: Demigod33Post Number: 107 Registered: Jun-04 | re x x x |
Visitor#78 Unregistered guest | Visonik is junk too. Are you just looking for Subs & Amp? If so $1000 gives you a lot of options. Like Jonathan suggested in another thread -1 Adire Audio Bramha $379 Shipped -1 MTX 1501d $362 shipped -1 1/O Gauge amp kit from www.Knukoncepts.com $80 Leaves $180 for the box, a case of bear and a movie |
New member Username: Chrisg001Sussex, WI United States Post Number: 7 Registered: Aug-04 | Yah just subs and amp I have tried ro email re for about a month now with no response i don't want to call becasue of the outrageous long distance chargs how can i purchase them otherwise. |
Silver Member Username: CaraudiofngHouston, TX Post Number: 142 Registered: Aug-04 | You can get the JBL GTO 1201.1 for about $300 shipped. the BP1200.1 is getting harder to find. Can get the Kicker 1200.1 for around $400 |
Silver Member Username: JmloughreyFarmington, CT Post Number: 205 Registered: Jul-04 | i beleive there is a site that had them, someone posted it about 3 days ago, i beleive they were in the UK but i dont think itd run you more then like 10 bucks more on shipping...whats the number for R.E.....just call on a cell phone...find a friend that has free long distance |
New member Username: Chrisg001Sussex, WI United States Post Number: 8 Registered: Aug-04 | Is it the www.bladeice.com and how do the adire brahma stack up against the RE line of subwoofers. |
Silver Member Username: InsearchofbassPost Number: 163 Registered: Jun-04 | buy what these guys are recomending cant go wrong with re or brahma but if you buy the amps they are suggesting either is good but keep your alternator in mind because they draw serious amps current wise ....oh im not sure of the ohms of the brahma and re but make sure you dont go below 2 oms mono with the mtx and 1 ohm with the jbl amp |
Silver Member Username: InsearchofbassPost Number: 164 Registered: Jun-04 | as matter of fact id upgrade the alternator with the rest cuz you know your going to have other amps for your highs as loud as those speakers are going to be |
Bronze Member Username: SlimSt.pete, Florida Post Number: 17 Registered: May-04 | heres some prices on re subs re8-$56 re10-$66 re12-$76 Se10-$165 Se12-$185 Se15-$215 Sx10-$260 Sx12-$270 Sx15-$290 Sx18-$320 X-X-X10-$395 X-X-X12-$405 X-X-X15-$435 X-X-X18-$475 MT10-$445 MT12-$455 MT15-$485 MT18-$525 JUST SOME PRICES ON RE SUBS |
New member Username: Chrisg001Sussex, WI United States Post Number: 9 Registered: Aug-04 | Thanks for the pricing. I think i might go with the 2-12" brahmas. What amp would be good to power them. |
