New member Username: Hsyn1453h
Post Number: 1 Registered: Jul-23
Posted on VMFL5E6M058878
Platinum Member Username: Regrooster
Post Number: 16736 Registered: Aug-08
Posted on try code 1747 |
Post Number: 2 Registered: Jul-23
Posted on It gave an error in 1747, it does not accept |
Post Number: 16741 Registered: Aug-08
Posted on M058878 code is definitely 1747 If you are entering the code correctly and it doesn't work then it looks like your radio may have been recoded in the past to a different number code entry instructions Switch radio ON, display shows CODE with " - - - - " flashing Press preset " 1 " repeatedly for 1st digit Press preset " 2 " repeatedly for 2nd digit Press preset " 3 " repeatedly for 3rd digit Press preset " 4 " repeatedly for 4th digit Press tuning button " > " to enter the code |
