Platinum Member Username: Regrooster
Post Number: 13235 Registered: Aug-08
Posted on Are you sure it needs a code as it shows IMMO in the database so is VIN coded and should work OK if it is still fitted in the original vehicle ? http://codedradio.info/?i=bn&st=bp9340 otherwise try code 7396 |
