Peugeot clarion radio code
Username: Mitchyboy
Had to change my battery and dont have the radio code.
serial number CL0410Y0038084
MODEL NO 2325-A
Can anyone please help
Username: Titanum123
Post Number: 1017
mitch
Username: Mitchyboy
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
Username: Heyno
need code for PU-2294A
CL040140925496C
please help me
Username: Iwos
Post Number: 972
dennis
Username: Heyno
Username: Heyno
Thanks Iwos i will look for that c... number and come back to you
