New member Username: Frankie1971Post Number: 1 Registered: Jul-13 | i am looking for a radio code for my nissian primastar if any one can help i would be much appreciated |
Gold Member Username: OpelopPost Number: 1578 Registered: Sep-12 | serial numbers from radio please contakt me http://forum.kody-radio.pl |
New member Username: Frankie1971Post Number: 2 Registered: Jul-13 | I am a bit unsure which the serial number is can you tell me what it would begin with have lots of numbers |
Platinum Member Username: RegroosterPost Number: 11594 Registered: Aug-08 | The correct radio SERIAL NUMBER is required for a code First remove the radio from the dashboard. Removal Info here www.fitaudio.com Then post the radio make+model plus all the letters+numbers on any labels,barcodes and a 14 character Serial Number stamped in the metal casing. This information can then be used to see if a code can be calculated |
