Code needed clarion pu2294a
Username: Taylors1085
Serial no cl0401y0484878
Username: Opelop
Post Number: 1515
taylors
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your
radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop
to read/recode the memory chip (EEPROM) inside your radio.
contakt me http://forum.kody-radio.pl
C70000005443
Username: Opelop
Post Number: 1516
taylors
CODE 6611
Username: Dekster
POLAND
Post Number: 1078
taylors
CODE 6611
CONTACT me
http://koddoradia.pl/\\
