Renault Laguna
Username: Mark30am
Hi all, I've just put my laguna back on the road after 3 years and had to change the battery. Does anyone have the code for the battery please ?
model RN258F20284385
PIN TOO572
ANY AND ALL HELP WILL BE MUCH APPRECIATED
THANKS FROM MARK
Username: Mark30am
SORRY I MEANT RADIO LOL
Username: Masterskay62
MelitopolUkraine
Post Number: 29
mark mccarron
Username: Mark30am
Try code 1491 or 9495 and post back which one works
Username: Wankel
Hi forum,
My radio has been out of service for some time now, after a problem with the battery. According to the repair shop, it is the reason the arconditioning does not work.
The code in the manual is not correct, and two four-number-codes on the radio/CD player are not accepted either.
Could you please help me?
The codes I found on the units are:
GPS
8200 339 742 ---
NO MODEL: RENMCC101-00
(BT2)
INDUS VDO: 0495027100276780
PROD No: FD0004120008385
Radio/CD
307 K74 1640724 1
Radio : 5833
COMPA PN6
Facade chang CD: 8360
KGRFOB31651684
AL R92S 40017
|eirl| SW 1.00
MW 1.201
020366
8 200 348 360--B
PN MH9RN920LC
8 200 089 153 T F446
S/NO.ALR92S91140017
The radio/CD player is full of stickers on the bottom, while the GPS unit (the one with the wheel and few buttons) only has four codes on one sticker). The S/NO is engraved in the metal housing.
Thanks in advance!
Username: Opelop
Post Number: 1490
wankel
Username: Wankel
TRY CODE 4300
contakt me http://forum.kody-radio.pl
Username: Wankel
Opelop,
Thank you for helping. I tried the code, but it does not work ("Error", and wait for 0000 to appear again).
I took a photo of the stickers, and it turned out I made a mistake typing two of the codes:
incorrect: 8 200 348 360--B
correct: 8 200 318 360--B
incorrect: S/NO.ALR92S91140017
correct: S/NO.ALR92S31140017
Does that make a difference? Sorry for not checking more careful in the first place.
Username: Opelop
Post Number: 1491
wankel
Username: Wankel
sorry we can't help
Main Dealer or a Decoding Service only for this code
Username: Wankel
Opelop,
Thanks again for your trouble!
Username: Mark30am
Hi masterskay62 the codes supplied didnt work ?
any further halp will be greatly appreciated
cheers
Username: Mark30am
any further help will be greatly appreciated
cheers
Username: Screwyloui
hi there, after having my laguna repaired my radio now wont work please help. the details are
MODEL NUMBER IS RENDRW100-10
SECURITY CODE IS TOA282
RNDR0130063728
PRODUCT NUMBER IS FD0003210063728
THANKS IN ADVANCE
Username: Dekster
POLAND
Post Number: 1077
screwyloui
CODE 0188
CONTACT me
http://koddoradia.pl/
Username: Herb300466
Wolverhampton, West Midlands United Kingdom
Post Number: 10
Hi hav had to take battery off my laguna and now the code I was given in january which worked fine won't go in is this common ?
Model 22dc277/62
Top938
Rn277f30107710
Prod no fd010306010
8200256141tp938
8200 256 141 --c
Code given was 0097 cheers
Username: Opelop
Post Number: 1505
herbie
CODE 0097
Post Number: 11
Thanks for fast reply but 0097 will not go back .that was code I was using and now radio won't accept it
Username: Mark30am
HI Masterkay,
The codes you supplied were good the one 9495 worked great.
Many thanks for your help. The mistake was me typing 9496 but 9495 worked great.
MANY MANY MANY THANKS AGAIN Mark
Hey Deckster, unfortunately that code didn't work any help would be VERY
Much appreciated, I hate having no music in my Brum Brum x
Username: Dekster
POLAND
Post Number: 1099
screwyloui
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE " Then " 0000 "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press and hold preset " 6 " To Enter
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " ¬ " On The Stalk Control To Enter
Press And Hold " ¬ " Until A Beep Is Heard
CONTACT me
