New member Username: DuwasPost Number: 4 Registered: Dec-12 | please can any one help me with my car radio code. I've had the battery replaced and now the original radio code won't work. When I enter it and press the button under the volume stalk, it just beeps at me. Peugeot clario Model: PU-1560 A Serial number 96 317412 ZL 0022293 |
Gold Member Username: OpelopPost Number: 1148 Registered: Sep-12 | Zakariya New member Username: Duwas Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. contakt me http://forum.kody-radio.pl |
