Renault laguna 2001
Username: Bebo99
hi can anyone help me get my stereo code for laguna 2001
891
k74 09 30586
radio: 2607
KG0G0624356795
RANDON
Thanks
Username: Regrooster
Post Number: 10155
Sorry.......this is insufficient information
The radio has to be removed from the dashboard
Then quote the 14 character SERIAL NUMBER beginning with
RN* * * * * * * * * * * * found stamped in the metal casing.
Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
