Renault Scenic 2.0 16V RXi - radio code
Username: Weskob
hi there,
can anyone help me get my radio code:
VIN No. : VF1JA1B0523231180
Engine No.: C023067
what other information do you need???
thx
Username: Regrooster
Post Number: 9651
The radio has to be removed from the dashboard
Then quote the 14 character SERIAL NUMBER beginning with
RN* * * * * * * * * * * * found stamped in the metal casing.
Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
