RE MEGANE I 96r.
Username: Marszu
I need the radio code for Renault
Model no: 22DC594/72f
PROD NO: FD0397133000437
PHILIPS
Can Anyone Help??
THANK YOU!!
Username: Regrooster
Post Number: 8568
Sorry.......this is insufficient information
The radio has to be removed from the dashboard
Then quote the 14 character SERIAL NUMBER beginning with
RN* * * * * * * * * * * * found stamped in the metal casing.
Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
Username: Marszu
I found COde Sorry for wasting your time ^^ THX !!
