hi i bought a renault laguna 1998 and no code for radio please help the kids are driving me insane; philips model 22DC459/62S number under barcode:7700426482K123 THANKS
(Note :If you don't have the [ ¬ ] button then push the thumbwheel in and some will have an [ A¬ ] button )
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit Press the [ ¬] button then rotate the thumb wheel for the correct second digit Press the [ ¬] button then rotate the thumb wheel for the correct third digit Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen, press and hold the [ ¬] button for up to 10 seconds to store the code
IF THERE IS NO STEERING WHEEL CONTROL , THEN USE THE PRESET BUTTONS ON THE RADIO
Press the First Preset Button repeatedly for the 1st digit to be displayed Press the Second Preset Button repeatedly for the 2nd digit to be displayed Press the Third Preset Button repeatedly for 3rd digit to be displayed Press the Fourth Preset Button repeatedly for 4th digit to be displayed
Then press and HOLD Preset button 6 for 10 seconds to store your code
(Note :Some radios use Preset Button 5 to store the code ) ==========================================
