Car 300 blaupunkt safe mode
Username: Vrecer
Hello,
the radio in my car entered safe mode after repairs and i don't have the code because i didn't get it when buying the car from previous owner.
I took out the radio and numbers are:
GM1300T5992832
7 645 852 320
type car 300(D)
90 532 620
Can please somene tell me the code?
thank you very much
Username: Regrooster
Post Number: 7698
Duplicate post...Already answered
Please do NOT post the SAME request in more than ONE thread
It is not necessary
Username: Cazar58
I have two problems : Changed my battery and now can't use my radio/cassette player, Blaupunkt CAR 300, in my R reg Vauxhall Corsa. In any case, I only get 7 SAFE when I switch on the ignition, and I get a beep when I press the AS button, but how do I get it to allow me to put in a code? I don't suppose there's a general code as I can't get the radio out to access the serial number. Any help would be most appreciated.
Post Number: 7754
To restore from 7SAFE press AS and ON button....and leave SWITCHED ON.....UNDISTURBED for as long as it takes to automatically reset.
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
