Alfa 147 Blaupunkt
Username: Mickpm
Code needed please for my Alfa as its not in the history:
Alfa 937 High
7 649 378 316
BP937817290143
Thanyou
Username: Regrooster
Post Number: 7409
Reminder :..NO MULTIPLE CODE REQUESTS ON THIS FORUM
Single free code for personal use only
This is to prevent abuse by traders+dealers, car radio thieves and other chancers
Sorry if you are one of the honest ones !
Username: Mickpm
Post Number: 7
Hi Reg and I can assure you I'm not a thief, trader or chancer. I've always used this forum for my radio codes and the one above is for a CD player that I've just purchased to replace my tape player unit which i'm looking for a code for.
Donation will be sent to the first person to supply the code.
Mick
Post Number: 7412
This is the 4th code request this year
This is for security reasons to prevent abuse by traders+dealers, car radio thieves and other chancers
Username: Maya21
bonjour,
mon autoradio d'origine est recemment tombe en panne. j'ai reussi a retrouver le meme (meme ref) pour ne pas avoir a m'embeter a adapter un nouveau poste a ma voiture (commande au volant notamment). seulement je n'ai pas le code... Est-il possible de l'avoir ?
Voici la ref : Alfa 937 High 7 649 378 316 BP937817595890
Merci infiniment !
Username: Hay88
PortsmouthUk
Post Number: 3572
Maya21
code 6634
Username: King2009
salut
j'ai acheter une 147 mais pour autoradio je n'ai pas le code
est-il possible de l'avoire
ref . alfa 937/ALFA 947 C1V2 CD 7646694316
815BP669487403302
MERCI
Post Number: 7640
king
Username: King2009
Posted on Friday, July 01, 2011 - 11:19 am:
salut
815BP669487403302
Try code 4472 or 2652
Please confirm which is correct
Username: Mushu
Bonjour, j'aimerai retrouver le code de mon autoradio alfa 147
ref: alfa-937 CD NS 7643301316
815BP330147129961
Merci d'avance
Post Number: 7685
Mushu
Username: Mushu
Posted on Tuesday, July 05, 2011 - 01:03 pm:
815BP330147129961
try code 6545
