Can you help?
Username: Daljatt
Hi there i have lost my code to a MG cd player. The serial numbers i got of the top of the stereo is: XQE000930PMA and VDCD3042023938. thanks
Username: Regrooster
Post Number: 7735
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
Username: Daljatt
That is all the letters and numbers on the MG cd player
Post Number: 7739
Sorry....Main Dealer or Radio Decoding Service only for this code
It will not be available for free or cheap from anywhere on the Internet
