Renault clio 02 radio code
Username: Red_head
Hi, could anyone please help me, i changed the battery in the car. The radio went off and it needs code now. Radio code for 02 Renault Clio
Model No: 22DC278/62B
TOK253
RN278F20149685
Product No: FD0202090149685
8200057681TK253
8200057681
If anyone knows code please let me know
Thanks
Username: Hay88
PortsmouthUk
Post Number: 3505
red head
code 5558
You must hold at the end to store your code.
IF YOU DONT HAVE A KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {AA} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ A] button then rotate the thumb wheel for the correct first digit
Press the [ A] button then rotate the thumb wheel for the correct second digit
Press the [ A] button then rotate the thumb wheel for the correct third digit
Press the [ A] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ A] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store.
Username: Red_head
Thanks a million hay88, the code worked no prob.Great result
Regards
Red Head
