Hi,after a flat battery my radio no longer works as it needs a security code,which I can't find,can anyone help! Model No:RENRDW100-10 G965 RNRD0141085964 Prod no:FD0404190185964 Serial no:8200247962TG965 On-line sites quoting £15 for code!!!!!!Any help would be great thanks in advance.
Here is a video showing how to remove a standard radio from the dashboard. A pair of extractors are required (available from Ebay etc ) but these can be made from 2 pieces of bent, wire coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4 securing clips
http://www.youtube.com/watch?v=urC-4NbXvDQ
note: on some radios , these 4 holes are protected by 4 small screws. These can be unscrewed using the appropriate size of Allen key.
thank you for guidance! with your help and as I read your discussions and replies I think that with the assistance of the 'renault pre code calculator' I will be succesfull tomorow. great forum!
