PU-2294A© code? Thank you
Username: Pgenov
Hi,
I have a peugeot 806 with
radio PU-2294A©
e13020410
286 8497 33
96 392 195 80
SN CL041Y0219618
it's locked. Please help me if you can.
Thank you
Username: Hay88
PortsmouthUk
Post Number: 2044
the only CLARION code available for free (using a serial number ) from anywhere on the Internet
is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service
or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
inside your radio
