HELP!! Ford Focus 1.6 2003 I need a code for my radio!!
Username: Mojorising
My battery had a loose connection and ultimately my radio is now asking for a code!! I have tried one that I saw on line for a 6000 CD RDS E-O-N, which is what mine is, but that was wrong so I am now down to 9 goes!! Could someone help?? I dont know where to locate any serial numbers...its not in the manual or the audio guide. Help would be much appreciated!! Cheers peeps
Username: Regrooster
Post Number: 4935
Remove the radio from the dashboard.
Then post the SERIAL NUMBER found on a label on the radio casing
It normally begins with M******
Video Demo here
http://www.youtube.com/watch?v=urC-4NbXvDQ
Hi there,
I went to Halfords, bought the DIN things and the serial number IS:
M365503. It is a 6000 CD RDS E-O-N on a FOCUS 1.6 2003 plate.
Thanks for your help so far....:-)
Post Number: 4938
Try code 2 6 1 4
Wow....worked straight away...thank you sooo much.
You're a STAR!!! :-)))
Nat
