Opel codes
Username: Jimdadub
hi can anyone help need codes for opel vivaro radio siemens 330886636 number 24469305 type cdr2005 thank you jimmy
Username: Regrooster
Post Number: 3623
Unfortunately the majority of SIEMENS/VDO codes (including yours) will NOT be available for free (or cheap) from anywhere on the Internet as access is required to the original factory database...which is not commercially available..
Try your Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are normally the cheapest option) who will connect it to a laptop to read/recode the memory chip (EEPROM)
