New member Post Number: 1 Registered: Sep-08 | Hi all, Just had to replace the battery in my scenic, which disconnected the Power and hence disabled my Stereo. The code in the book says 9400, and also 0114 in pen along side it. Unfortunately for me neither of these work and the stereo wont unlock. The Model No is: RENRDW132-10 RNRD0440104694 Product No: FD0604350104694 there is an additional bar code: 8200300859TK400 Hope someone can help, wife is driving me mad, cause of course its my fault! Best regards, |
New member Post Number: 4 Registered: Aug-08 | Model No is: RENRDW132-10 RNRD0440104694 Product No: FD0604350104694 there is an additional bar code: 8200300859TK400 Code is 5182 |
New member Nigeria, Lagos Nigeria Post Number: 1 Registered: Sep-08 | Hello all, Just had to replace the battery in my honda acedemy, which disconnected the Power and hence disabled my Stereo.i cant find my manual.pls i need urgent HELP!!!!! MOdel No is :39100SV4A500 Seria No:M96G185748 |
Bronze Member Post Number: 42 Registered: Aug-08 | ezekiel salifu Username: Ezekiels Posted on Tuesday, September 30, 2008 - 11:52 am: Just had to replace the battery in my honda acedemy, which disconnected the Power and hence disabled my Stereo.i cant find my manual.pls i need urgent HELP!!!!! MOdel No is :39100SV4A500 Seria No:M96G185748 Sorry , this is a MATSUSHITA radio and the codes are not available on any of these free Help Boards. Main Dealer or Radio Decode Specialist only |
New member Post Number: 1 Registered: Oct-08 | Hello! Just had to replace the battery in my Renault Clio II, which disconnected the Power and hence disabled my Stereo. The code in the book says 4100. Unfortunately this code doesn't work and the stereo is unlock. The Model No is: 22DC259/62F RN259FY0162933 Product No: FD0200330162933 an additional bar code: 820029539TQ747 Hope someone can help, wife is driving me mad, cause of course its my fault! Thankful in advance |
Bronze Member Username: RegroosterPost Number: 46 Registered: Aug-08 | Rem_1 Posted on Wednesday, October 01, 2008 - 12:00 pm: Just had to replace the battery in my Renault Clio II, which disconnected the Power and hence disabled my Stereo. The code in the book says 4100. Unfortunately this code doesn't work and the stereo is unlock. The Model No is: 22DC259/62F RN259FY0162933 Product No: FD0200330162933 an additional bar code: 820029539TQ747 Sorry , this one is another one of the French (Renault )Philips radios and is not in my database.(My database only appears to have around 50% of them ) Try restoredclassic@aol.com as they have a larger database and can normally calculate these French models ( Mention this forum and there should be no charge) |
New member Username: Thomas276Post Number: 1 Registered: Feb-09 | Hello! I need code for Renault Scenic 2004 BUILT-IN car radio Model. no: RENDRW133-10 W175 SECURITY RNRD0540055116 Prod. no: FD0404220055116 8200300860TW175 820 300 860 --B E2029021 00555116 N28 best regards |
Silver Member Username: RegroosterPost Number: 512 Registered: Aug-08 | Tomas Svab New member Username: Thomas276 Post Number: 1 Registered: Feb-09 Posted on Friday, February 13, 2009 - 01:53 pm: -------------------------------------------------------------------------------- Hello! I need code for Renault Scenic 2004 BUILT-IN car radio Model. no: RENDRW133-10 W175 SECURITY RNRD0540055116 Prod. no: FD0404220055116 8200300860TW175 820 300 860 --B E2029021 00555116 N28 ===================================================================== Try 3827 |
New member Username: MetaljerryPost Number: 1 Registered: Feb-09 | Hi, can You help me? I lost the code for my ford radio (ford escort) I want to built it in a ford focus. Model 6000 CD Radio and serial number is M166499 Thnaks ! |
Silver Member Username: RegroosterPost Number: 516 Registered: Aug-08 | Stamm New member Username: Metaljerry Post Number: 1 Registered: Feb-09 Posted on Saturday, February 14, 2009 - 10:06 am: -------------------------------------------------------------------------------- Hi, can You help me? I lost the code for my ford radio (ford escort) I want to built it in a ford focus. Model 6000 CD Radio and serial number is M166499 ================================================================== Your code is 0515 |
New member Username: MetaljerryPost Number: 2 Registered: Feb-09 | It works! Thanks a lot! |
New member Username: IgitonPost Number: 4 Registered: Feb-08 | Hello I need help for my car radio. Auto is Renault scenic 2 2005. product no: FD0105420004168 8200 550 823 8200550823TD138 Thanks in advance! |
Silver Member Username: RegroosterPost Number: 591 Registered: Aug-08 | Igor New member Username: Igiton Post Number: 4 Registered: Feb-08 Posted on Friday, February 27, 2009 - 03:52 am: -------------------------------------------------------------------------------- Hello I need help for my car radio. Auto is Renault scenic 2 2005. product no: FD0105420004168 8200 550 823 8200550823TD138 =================================================================== Your code should be 1138 |
New member Username: MattyvrsPost Number: 1 Registered: Mar-09 | Hi, I would really appreciate some help unlocking my 2001 clio 'TUNER LIST' cd player, details as follws; The Model No is: 22DC278/62H RN278F10006306 Product No: FD0201430006306 There is an additional bar code: 8200057683TR325 Any help would be gratefully appreciated Thanks, Matt |
Silver Member Username: RegroosterPost Number: 749 Registered: Aug-08 | matthew purssell New member Username: Mattyvrs Post Number: 1 Registered: Mar-09 Posted on Sunday, March 22, 2009 - 08:21 am: -------------------------------------------------------------------------------- Hi, I would really appreciate some help unlocking my 2001 clio 'TUNER LIST' cd player, details as follws; The Model No is: 22DC278/62H RN278F10006306 Product No: FD0201430006306 There is an additional bar code: 8200057683TR325 ========================================================== Sorry...not in my PHILIPS database |
Bronze Member Username: DecodePost Number: 41 Registered: Jan-09 | matthew purssell ------> code 8668 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation... this is my paypal ( www.paypal.com ) e mail: lynx222@o2.pl |
New member Username: SneekysharkLiverpool Post Number: 2 Registered: Apr-09 | Hi i have the same problem except my new 1 wk old alpine stereo was stolen last night when my car was broken into, ive put my old tuner list unit back in and yes it needs a code what a week my model number is 22DC258/62P my product number is FD0203070098744 there is another number which is 8200152345TW332 if any one can help that would be great. I have also listed the help message on an other link on this forum wsnt to sure where to ask for help. Thank You Dave |
Silver Member Username: RegroosterPost Number: 877 Registered: Aug-08 | david williams New member Username: Sneekyshark Liverpool Post Number: 2 Registered: Apr-09 Posted on Saturday, April 18, 2009 - 05:06 pm: -------------------------------------------------------------------------------- Hi i have the same problem except my new 1 wk old alpine stereo was stolen last night when my car was broken into, ive put my old tuner list unit back in and yes it needs a code what a week my model number is 22DC258/62P my product number is FD0203070098744 there is another number which is 8200152345TW332 if any one can help that would be great. I have also listed the help message on an other link on this forum wsnt to sure where to ask for help. ----------------------------------------------------------- Your code is 3658 |
New member Username: RosroyPost Number: 1 Registered: Apr-09 | Hi, Everybody ! I'd like to ask you for a help or an advice. Recently I bought a second-hand Renault Megane which is equiped with Philips car radio-cassette player "Tuner List". Its Model No= 22DC259/62P , the Prod No= FD0200040040994 and there are another two labels: RN259FY0040994 and TOY707. Can someone calculate its code ? I remember 3 years ago I found an on-line Internet calculator for such Philips car audio systems (then I needed a code for Opel Combo car), but now I can't find it again... Many thanks in advance ! Rossen |
Bronze Member Username: DecodePost Number: 98 Registered: Jan-09 | Rossen Nestoroy ------> code 1287 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation... this is my paypal ( www.paypal.com ) e mail: lynx222@o2.pl |
New member Username: AkobPost Number: 1 Registered: Apr-09 | I need code for Renault Scenic Model No: RENRDW233-70 RNRD8560025789 Product No:FDO 1060 500 25784 8200-550 823 8200-550 823 J 315 SECURITY |
Bronze Member Username: DecodePost Number: 99 Registered: Jan-09 | Akob ------> code 7365 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation... this is my paypal ( www.paypal.com ) e mail: lynx222@o2.pl |
New member Username: Star21Post Number: 1 Registered: Apr-09 | Please, try code, for Philips Model ¹ 22DC459/62E Prod. ¹ FD0898292096367 FD 08 98 29 2096367 |
Silver Member Username: RegroosterPost Number: 946 Registered: Aug-08 | Vasil New member Username: Star21 Post Number: 1 Registered: Apr-09 Posted on Wednesday, April 29, 2009 - 06:13 am: -------------------------------------------------------------------------------- Please, try code, for Philips Model ¹ 22DC459/62E Prod. FD0898292096367 FD 08 98 29 2096367 ====================================================== Quote ALL the LETTERS+NUMBERS on ANY BARCODES , LABELS or STAMPED IN THE METAL CASING. There should be a 14 character Serial Number beginning with RG or RN or PH or similar |
New member Username: EriksaPost Number: 1 Registered: Apr-09 | dear god please help me out here renault scenic built in radio/cd mod no: 22DC279 / 62P Prod No: FD0100170082050 other codes appearing on it are as follows: T0S879 RN279FY0082050 7700434425TS879 7700 434 425 in the back of the radio, imprinted in the metal, it says: e 2 029021 I know the original code, it says to be 2653, but it does not work. Please help =0 |
Silver Member Username: DecodePost Number: 108 Registered: Jan-09 | erik björkman ------> code 7196 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation... this is my paypal ( www.paypal.com ) e mail: lynx222@o2.pl |
New member Username: B3atsPost Number: 1 Registered: May-09 | Hello, Would someone be able to provide me with a code for my Scenic - 54 Plate - Stereo. Details from the unit as follows (this is all info from various stickers, etc): Model Number: RENRDW131-10 K496 Security RNRD0340222663 Prod No: FD0704430222663 Barcode: 8200300858TK496 8200 300 858 --B REN9268 Back Of Stereo - Imprinted in the metal: e 2 029021 If someone could help I would be very grateful. Cheers, Dan |
Silver Member Username: RegroosterPost Number: 956 Registered: Aug-08 | Dan Eaton New member Username: B3ats Post Number: 1 Registered: May-09 Posted on Friday, May 01, 2009 - 03:31 pm: -------------------------------------------------------------------------------- Hello, Would someone be able to provide me with a code for my Scenic - 54 Plate - Stereo. Details from the unit as follows (this is all info from various stickers, etc): Model Number: RENRDW131-10 K496 Security RNRD0340222663 Prod No: FD0704430222663 Barcode: 8200300858TK496 8200 300 858 --B REN9268 Back Of Stereo - Imprinted in the metal: e 2 029021 If someone could help I would be very grateful. Cheers, Dan ================================================== Duplicate post....Already answered |
New member Username: MerlijnPost Number: 1 Registered: May-09 | After building in a Car kit, I found out that the code supplied from the manufacturer is not correct for my Tuner List Radio in my Laguna Grand Tour( 2001). Could someone have a look and see what the code is for these numbers: Model: Renault Tuner List Model No: 22DC279/62Z T0S339 RN279F10139651 Prod No: FD0101350139651 Barcode says 8200002607TS339 Top Label says: 988 K74 3741237 1 Radio 2607 KG0M0525589511 Thanks very much! |
Silver Member Username: RegroosterPost Number: 994 Registered: Aug-08 | Bjorn New member Username: Merlijn Post Number: 1 Registered: May-09 Posted on Monday, May 11, 2009 - 08:22 am: -------------------------------------------------------------------------------- After building in a Car kit, I found out that the code supplied from the manufacturer is not correct for my Tuner List Radio in my Laguna Grand Tour( 2001). Could someone have a look and see what the code is for these numbers: Model: Renault Tuner List Model No: 22DC279/62Z T0S339 RN279F10139651 Prod No: FD0101350139651 Barcode says 8200002607TS339 Top Label says: 988 K74 3741237 1 Radio 2607 KG0M0525589511 -------------------------------------------------------------------------------- ----- Your code is 7645 |
New member Username: SiePost Number: 1 Registered: May-09 | I have brought a renault megane scenic at auction and the stereo is asking for a code i was wondering if any one could give me the code Model Tuner List Model Number 22DC259/62P TOG591 RN259F10254449 Prod No FD0501140254449 Barcode says 7700434424TG591 I would be very grateful if someone can help asap Thanks |
Silver Member Username: RegroosterPost Number: 996 Registered: Aug-08 | Simon Hill New member Username: Sie Post Number: 1 Registered: May-09 Posted on Monday, May 11, 2009 - 06:22 pm: -------------------------------------------------------------------------------- I have brought a renault megane scenic at auction and the stereo is asking for a code i was wondering if any one could give me the code Model Tuner List Model Number 22DC259/62P TOG591 RN259F10254449 Prod No FD0501140254449 Barcode says 7700434424TG591 I would be very grateful if someone can help asap Thanks ===================================================== Your code is 6429 |
New member Username: SiePost Number: 2 Registered: May-09 | i have just gone to put code into model 22dc259/62p and have noticed that when it asks for code it isnt displaying 0000 could you help me thanks |
Silver Member Username: DecodePOLAND Post Number: 144 Registered: Jan-09 | Simon Hill--->http://www.radio-code.co.uk/code-entry-help.php |
New member Username: Star21Post Number: 2 Registered: Apr-09 | Hello, sory, then it must be the numbers you need RN459FW2 096367 bar code: 77004264830487 thanks! |
Gold Member Username: RegroosterPost Number: 1002 Registered: Aug-08 | Vasil New member Username: Star21 Post Number: 2 Registered: Apr-09 Posted on Wednesday, May 13, 2009 - 03:47 am: -------------------------------------------------------------------------------- Hello, sory, then it must be the numbers you need RN459FW2 096367 bar code: 77004264830487 ==================================================== Sorry...not in my PHILIPS database |
New member Username: Star21Post Number: 3 Registered: Apr-09 | OK Thank you very much! |
New member Username: Cruiser89Post Number: 1 Registered: May-09 | Hi there, Was doing some work on my car and unfortunately I need the code. Eek. Anyway the numbers I have are: RNRD5950028349 RENRDW220-60 FD0205430026348 8200483751T Any help would be great. Cheers, Tim |
Gold Member Username: RegroosterPost Number: 1029 Registered: Aug-08 | Tim b New member Username: Cruiser89 Post Number: 1 Registered: May-09 Posted on Sunday, May 17, 2009 - 03:12 pm: -------------------------------------------------------------------------------- Hi there, Was doing some work on my car and unfortunately I need the code. Eek. Anyway the numbers I have are: RNRD5950028349 RENRDW220-60 FD0205430026348 8200483751T Any help would be great. -------------------------------------------------------------------------------- --------- Sorry...not in my Philips database |
New member Username: MrpastaPost Number: 1 Registered: May-09 | Hi can someone give me a code for Renault Scenic, please Model No: RENRDW 232-10 RNRD 415 001 4341 Product No: FDO 4053 6001 4341 Other Numbers 8200-367 492T V135 SECURITY many thanks |
Gold Member Username: RegroosterPost Number: 1059 Registered: Aug-08 | Richie Turner New member Username: Mrpasta Post Number: 1 Registered: May-09 Posted on Saturday, May 23, 2009 - 12:05 pm: -------------------------------------------------------------------------------- Hi can someone give me a code for Renault Scenic, please Model No: RENRDW 232-10 RNRD Product No: FDO 4053 6001 4341 Other Numbers 8200-367 492T V135 SECURITY -------------------------------------------------------------------------- Your code is 4822 |
New member Username: MrpastaPost Number: 2 Registered: May-09 | magic, thanks very much |
New member Username: AddzshadyTralee, County Kerry Ireland Post Number: 1 Registered: Jun-09 | would someone have the radio code for a 2004 Renault Scenic the Codes are :} Model Number- RENRDW132-10 Product Number- FD0404140068470 Other Numbers RNRD0440068470 8200300859TL235 Thank You |
Silver Member Username: DecodePOLAND Post Number: 175 Registered: Jan-09 | Adam Newstead ------> code 3592 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation... this is my paypal ( www.paypal.com ) e mail: lynx222@o2.pl |
New member Username: Mistryash1Post Number: 1 Registered: Jun-09 | Just had a new starter motor put in and now the radio will not work! I put in the code that came with the car which was "3641", but won't accept it! I was wondering if any one could give me the code for my Megan Scenic 2003 radio. Model Number 22DC258/62P TOH343 RN258F20085483 Prod No FD0102460085483 Barcode says 8200152345TH343 I would be very grateful if someone can help asap Thanks |
Gold Member Username: RegroosterPost Number: 1259 Registered: Aug-08 | ashok mistry New member Username: Mistryash1 Post Number: 1 Registered: Jun-09 Posted on Wednesday, June 17, 2009 - 04:49 pm: -------------------------------------------------------------------------------- Just had a new starter motor put in and now the radio will not work! I put in the code that came with the car which was "3641", but won't accept it! I was wondering if any one could give me the code for my Megan Scenic 2003 radio. Model Number 22DC258/62P TOH343 RN258F20085483 Prod No FD0102460085483 Barcode says 8200152345TH343 I would be very grateful if someone can help asap Thanks ================================================== Sorry...not in my database |
New member Username: GlobespanscottPost Number: 1 Registered: Jun-09 | Hi There Got my car back today from a routine service, they have disconnected my battery for some reason and now I have no radio. I hope someone can help me please with a code for this radio cassette player. My Car is a renault Megane Scenic 2003. When I pulled the stero out I got these codes Model Number.22DC258/62P Prod Number FD0102480087564 Other codes on it were TOK283 RN258F20087564 8200152345--A Thanks you to anyone who can help |
Silver Member Username: DecodePOLAND Post Number: 196 Registered: Jan-09 | Scott McRoberts ------> code 5559 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation... this is my paypal ( www.paypal.com ) e mail: lynx222@o2.pl |
Silver Member Username: DecodePOLAND Post Number: 197 Registered: Jan-09 | ashok mistry ------> code 4021 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation... this is my paypal ( www.paypal.com ) e mail: lynx222@o2.pl |
New member Username: GlobespanscottPost Number: 2 Registered: Jun-09 | THanks for the try Michael, just tried it but itwas the wrong one, Thanks anyway |
Gold Member Username: RegroosterPost Number: 1280 Registered: Aug-08 | Scott McRoberts New member Username: Globespanscott Post Number: 2 Registered: Jun-09 Posted on Saturday, June 20, 2009 - 02:18 pm: -------------------------------------------------------------------------------- THanks for the try Michael, just tried it but itwas the wrong one, Thanks anyway ==================================================== The code you were quoted 5559 is the correct code for your Serial Numbers Try emailing restoredclassic@aol.com for free advice Mention this forum |
New member Username: Jaero13Post Number: 1 Registered: Jun-09 | Model no: 22dc277/62 tov392 rn277f30085517 prod no: fd0103010085517 bar code: 8200256141TV392 |
Silver Member Username: DecodePOLAND Post Number: 204 Registered: Jan-09 | jarek ------> code 4653 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation... this is my paypal ( www.paypal.com ) e mail: lynx222@o2.pl |
New member Username: Made_in_euPost Number: 1 Registered: Jun-09 | Hi, I need a code for a tuner list. TOV123 RN278F20316259 Prod. No: FD0302450316259 and i understand that some people like beer. :-) |
Gold Member Username: RegroosterPost Number: 1289 Registered: Aug-08 | <i> New member Username: Made_in_eu Post Number: 1 Registered: Jun-09 Posted on Monday, June 22, 2009 - 03:03 pm: Hi, I need a code for a tuner list. TOV123 RN278F20316259 Prod. No: FD0302450316259</I =================================================== Your code is 4883 |
New member Username: JonthegoonerPost Number: 1 Registered: Jun-09 | hi can someone give me the code for scenic radio modle no. 22dc459/62l bar code :7700426412w485 any help would be much appreiciated thanks |
Silver Member Username: DecodePOLAND Post Number: 207 Registered: Jan-09 | jon redford ------> code 3536 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation... this is my paypal ( www.paypal.com ) e mail: lynx222@o2.pl |
New member Username: AlanidanezPost Number: 1 Registered: Jun-09 | hi, i from argentina. my english is bad, sorry. i don`t remember my code radio of my car, is a 22DC259/62F philips by renault clio. The dates of the stereo: model nº: 22dc259/62f T0o917 RN259FY0044554 prdo nº: HC0200010044554 8200029539TO917 8200 029 539 i need help. thank you |
Gold Member Username: RegroosterPost Number: 1307 Registered: Aug-08 | ñez New member Username: Alanidanez Post Number: 1 Registered: Jun-09 Posted on Friday, June 26, 2009 - 12:40 am: hi, i from argentina. my english is bad, sorry. i don`t remember my code radio of my car, is a 22DC259/62F philips by renault clio. The dates of the stereo: model nº: 22dc259/62f T0o917 RN259FY0044554 prdo nº: HC0200010044554 8200029539TO917 8200 029 539 ========================================= You have asked this question on different forums and have already been given the answer so I won`t waste any more of my time ! |
New member Username: Heskey_87Post Number: 1 Registered: Jul-09 | Hello, I need a code for cassette systems for Renault Scenic 2000 years Prod NO: FD 1100018060494 Model No: 22DC461/62P Please help. |
Gold Member Username: RegroosterPost Number: 1439 Registered: Aug-08 | Hasan Mustafov Kamberov New member Username: Heskey_87 Post Number: 1 Registered: Jul-09 Posted on Thursday, July 16, 2009 - 07:42 am: Hello, I need a code for cassette systems for Renault Scenic 2000 years Prod NO: FD 1100018060494 Model No: 22DC461/62P ==================================== Please quote ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING |
New member Username: EricpaulParicFrance Post Number: 1 Registered: Jul-09 | hi can someone help me for a code? Model no 22DC278/62B RN278F30684930 prod no FD0603500684930 thanks |
New member Username: Gmaks38Post Number: 1 Registered: Jul-09 | My Car is a renault Scenic 2003. When I pulled the stero out I got these codes Model Number.22DC258/62P Prod Number FD0203180110559 Other codes on it were "IG 739 RN258F30110559 8200152345"G739 |
Gold Member Username: RegroosterPost Number: 1467 Registered: Aug-08 | aks New member Username: Gmaks38 Post Number: 1 Registered: Jul-09 Posted on Tuesday, July 21, 2009 - 04:45 pm: My Car is a renault Scenic 2003. When I pulled the stero out I got these codes Model Number.22DC258/62P Prod Number FD0203180110559 Other codes on it were "IG 739 RN258F30110559 8200152345"G739 ================================== Do NOT post DUPLICATE REQUESTS in different threads It is both timewasting and annoying ! Already answered ! |
Gold Member Username: RegroosterPost Number: 1468 Registered: Aug-08 | ericpaul New member Username: Ericpaul Paric France Post Number: 1 Registered: Jul-09 Posted on Sunday, July 19, 2009 - 03:41 pm: hi can someone help me for a code? Model no 22DC278/62B RN278F30684930 prod no FD0603500684930 ============================================= Sorry...not in my database Try emailing restoredclassic@aol.com to see if they can help. Mention this forum |
New member Username: BarronalossaPost Number: 3 Registered: Aug-09 | Hi, i need help unlocking my Renault Scenic Cd Player ... Model: 22DC279-GP T0D093 RN279F00005607 Thanks .... |
Gold Member Username: RegroosterPost Number: 1568 Registered: Aug-08 | william santos New member Username: Barronalossa Post Number: 3 Registered: Aug-09 Posted on Saturday, August 08, 2009 - 03:05 pm: Hi, i need help unlocking my Renault Scenic Cd Player ... Model: 22DC279-GP T0D093 RN279F00005607 ================================= Try code 1916 |
New member Username: MajorquinPost Number: 1 Registered: Sep-09 | Big help needed Renault cd codes for my Scenic year 2001 Model 22DC279/62T Tol: 497 RN 279F20196709 MUCH APPRECIATED IF SOMEBODY COULD HELP GRACIAS.... |
Silver Member Username: DecodePOLAND Post Number: 256 Registered: Jan-09 | Juan Bibiloni--->3177 or 0776 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation... this is my paypal ( www.paypal.com ) site: https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=5341757 |
New member Username: As50215Post Number: 1 Registered: Sep-09 | Hi I have same problem changed battery on car and code thats in my book doesnt work I guess they have changed the head unit at some point, its a Renaul Laguna II Tuner List following details Model: 22DC279/62Z TON 208 RN279FY0010350 Prod No: FD0100440010350 Any help you could give would be appreciated |
Silver Member Username: DecodePOLAND Post Number: 281 Registered: Jan-09 | Adam Sibbald--->2708 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation... this is my paypal ( www.paypal.com ) site: https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=5341757 |
New member Username: CamparyRomania Post Number: 3 Registered: May-08 | Hello! Need code for RENAULT Model 22DC259/62F T904 SECURITY RN259F40452308 PROD No: FD1204430452308 8200029539TT904 8200 029 539 --F Thank you in advance! |
New member Username: MwflipperPost Number: 1 Registered: Sep-09 | Hello, i just had to replace the battery in my Megane with has an Tuner List radio. After starting the radio it asks for the CODE. In the registration document i found a 4 digit number, but it wont work with it. I found the following numbers at the radio: RN2777F20046348 Model No 22DC277/62 Prod.No FD0002440046348 Can you help me please? |
Silver Member Username: DecodePOLAND Post Number: 291 Registered: Jan-09 | mwflipper--->post all numbers from radio |
Silver Member Username: DecodePOLAND Post Number: 292 Registered: Jan-09 | adrian--->6012 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation... this is my paypal ( www.paypal.com ) site: https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=5341757 |
New member Username: MwflipperPost Number: 2 Registered: Sep-09 | Michael---> RN2777F20046348 Model No 22DC277/62 Prod.No FD0002440046348 T0Q329 Barcode 8200256141TQ329 8200 256 141 --- |
Silver Member Username: DecodePOLAND Post Number: 295 Registered: Jan-09 | Sorry...not in my database. Try emailing radiocodeservice@gmail.com to see if they can help |
New member Username: MwflipperPost Number: 3 Registered: Sep-09 | Sorry Michael, this was a mission impossible. It write one 7 to much in RN2777F20046348 So the correct data are RN277F20046348 Model No 22DC277/62 Prod.No FD0002440046348 T0Q329 Barcode 8200256141TQ329 8200 256 141 --- |
New member Username: MwflipperPost Number: 4 Registered: Sep-09 | Hi Michael, can you look in your database for the nr RN277F20046348 please? Thanks a lot. MWFlipper |
Silver Member Username: DecodePOLAND Post Number: 302 Registered: Jan-09 | Sorry...not in my database. Try emailing radiocodeservice@gmail.com to see if they can help |
New member Username: Andrew70115Post Number: 1 Registered: Sep-09 | Hi I need a code number for a renault scenic megane car radio, model number 22DC279/62p TOU264 RN279FY0038611 Prod number FD0100050038611 7700434425TU264 can anyone help me? thanks |
Silver Member Username: DecodePOLAND Post Number: 305 Registered: Jan-09 | andrew deopante--->5726 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation... this is my paypal ( www.paypal.com ) site: https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=5341757 |
New member Username: Andrew70115Post Number: 2 Registered: Sep-09 | Thanks michael...that was a gr8 help |
New member Username: MajorquinPost Number: 2 Registered: Sep-09 | Help,, Help,, Could anybody pass me the codes for the Car radio cd player fo my Peugeot.. VDO RD3-01 VDAPSF30320690 REF.PEUGEOT MODEL N, PSARCD100-01 PROD N, FDO103200320690 VSDO320690 THANKS IN ADVANCE, AS HERE IN SPAIN NOBODY SEEMS TO KNOW ... |
Gold Member Username: RegroosterPost Number: 2013 Registered: Aug-08 | Juan Bibiloni New member Username: Majorquin Post Number: 2 Registered: Sep-09 Posted on Sunday, October 11, 2009 - 01:48 pm: Help,, Help,, Could anybody pass me the codes for the Car radio cd player fo my Peugeot.. VDO RD3-01 VDAPSF30320690 REF.PEUGEOT MODEL N, PSARCD100-01 PROD N, FDO103200320690 VSDO320690 THANKS IN ADVANCE, AS HERE IN SPAIN NOBODY SEEMS TO KNOW =================================== VDO radios are difficult to decode Try emailing restoredclassic@aol.com to see if they can help Mention this forum |
New member Username: GraePost Number: 1 Registered: Oct-09 | Dear all, I search for the correct Code for: 22DC279/62 N985 Security RN279F40306905 FD0904150306905 7700433948TN985 7700433948 Thanks a lot Regards |
Silver Member Username: DecodePOLAND Post Number: 321 Registered: Jan-09 | Riniker Phil--->2086 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation... this is my paypal ( www.paypal.com ) site: https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=5341757 |
New member Username: CamparyRomania Post Number: 4 Registered: May-08 | 22DC229/62 TOL134 RN229F20106249 Prod No. FD 0402430106249 Thank you! |
Gold Member Username: RegroosterPost Number: 2046 Registered: Aug-08 | adrian New member Username: Campary Romania Post Number: 4 Registered: May-08 Posted on Thursday, October 15, 2009 - 01:27 pm: 22DC229/62 TOL134 RN229F20106249 Prod No. FD 0402430106249 Thank you! ------------------------------------------------------------ Try code 3751 |
New member Username: Thomas176Post Number: 1 Registered: Oct-09 | Hi all, 22DC279/62T T0X282 RN279FY0025996 PROD No. FD0100110025996 Cheers! |
Silver Member Username: DecodePOLAND Post Number: 345 Registered: Jan-09 | tom--->2789 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation... this is my paypal ( www.paypal.com ) site: https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=5341757 |
New member Username: Christy611Post Number: 1 Registered: Nov-09 | hi could anybody please supply me with the four digit code for my renault tuner list radio MOD NO 22DC258/62P TOT373 RN258F1OOO1758 PROD NO FDOOO151OOO1758 ANY HELP REALLY APPRECIATED THANK YOU |
Silver Member Username: DecodePOLAND Post Number: 387 Registered: Jan-09 | chris miller--->6626 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation... this is my paypal ( www.paypal.com ) site: https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=5341757 |
New member Username: Mhd270Post Number: 1 Registered: Dec-09 | Hello !! my language is very weak >> I'm sorry ... I need code for Renault Scenic 2004 car radio + CD player --------------------------------------------------------------- JA0C D039681 E2 SAN913 SAN513 MV632 DRAP08 HARM02 0 / ACCK MRTW VF1JA0C0224982550 ------------------------------------------------------------- This data is behind the door If incomplete data that you need me I hope illustration |
New member Username: Happy555Post Number: 1 Registered: Dec-09 | Hello Dear Reg Rooster! I hope you can help me! I need a code for Renault Scenic 2006 BUILT-IN car radio Model. no: RENRDW333-10 V543 SECURITY RNRDBQ60001367 Prod. no: FD0006170001367 Bar code: 8200633644T Engraved no: (e2)0204064 Thank You! Szepi. |
Gold Member Username: RegroosterPost Number: 2476 Registered: Aug-08 | ashour New member Username: Mhd270 Post Number: 1 Registered: Dec-09 Posted on Saturday, December 05, 2009 - 09:57 am: Hello !! my language is very weak >> I'm sorry ... I need code for Renault Scenic 2004 car radio + CD player --------------------------------------------------------------- JA0C D039681 E2 SAN913 SAN513 MV632 DRAP08 HARM02 0 / ACCK MRTW VF1JA0C0224982550 ====================== There should be a 14 character Serial Number beginning with RG or RN or PH or similar (often found stamped in the metal casing ) and maybe a Security Number in the format of TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING you can find |
Gold Member Username: RegroosterPost Number: 2477 Registered: Aug-08 | Happy555 New member Username: Happy555 Post Number: 1 Registered: Dec-09 Posted on Monday, December 07, 2009 - 10:54 am: Hello Dear Reg Rooster! I hope you can help me! I need a code for Renault Scenic 2006 BUILT-IN car radio Model. no: RENRDW333-10 V543 SECURITY RNRDBQ60001367 Prod. no: FD0006170001367 Bar code: 8200633644T Engraved no: (e2)0204064 ------------------------------------------------------------ Try code 4596 |
New member Username: LikealobsterLeeds Post Number: 1 Registered: Dec-09 | HELP! I have this problem with my Renault Grand Scenic, Where can I find the information needed to get the code. Cheers} |
Gold Member Username: RegroosterPost Number: 2645 Registered: Aug-08 | Nade New member Username: Likealobster Leeds Post Number: 1 Registered: Dec-09 Posted on Monday, December 21, 2009 - 03:10 pm: HELP! I have this problem with my Renault Grand Scenic, Where can I find the information needed to get the code. =========================================== try emailing restoredclassic@aol.com for advice + code Mention this forum |
New member Username: Joseva4Post Number: 1 Registered: Dec-09 | Espero que puedan ayudarme! Necesito un codigo para Renault privilegio lujo escénico. n º de modelo: RENRDW 133-10 W122 / seguridad RNRD0540086520 Prod. n º: FD0704460086520 Codigo de barras: 8200300860T Gracias! |
Gold Member Username: RegroosterPost Number: 2671 Registered: Aug-08 | joseva New member Username: Joseva4 Post Number: 1 Registered: Dec-09 Posted on Sunday, December 27, 2009 - 03:07 pm: Espero que puedan ayudarme! Necesito un codigo para Renault privilegio lujo escénico. n º de modelo: RENRDW 133-10 W122 / seguridad RNRD0540086520 Prod. n º: FD0704460086520 Codigo de barras: 8200300860T ================================================ Insufficient information Security Number also required In the format TOA123 or TA123 or just A123 at the end of a barcode see http://www.davidsonelectronics.co.uk/images/Serial_Locate/DC248_DC259.gif |
New member Username: Joseva4Post Number: 2 Registered: Dec-09 | Lo siento ... Codigo de barras: 8200300860TW122 |
Gold Member Username: RegroosterPost Number: 2702 Registered: Aug-08 | joseva New member Username: Joseva4 Post Number: 1 Registered: Dec-09 Posted on Sunday, December 27, 2009 - 03:07 pm: Espero que puedan ayudarme! Necesito un codigo para Renault privilegio lujo escénico. n º de modelo: RENRDW 133-10 W122 / seguridad RNRD0540086520 Prod. n º: FD0704460086520 Codigo de barras: 8200300860T Codigo de barras: 8200300860TW122 ================================================= Try code 3810 |
New member Username: DidlyrooPost Number: 1 Registered: Dec-09 | just wondering if anyone as the code for renault sceinic radio model no22dc258/62p prod no fd0002040008503 any help would be great |
Gold Member Username: RegroosterPost Number: 2724 Registered: Aug-08 | rob New member Username: Didlyroo Post Number: 1 Registered: Dec-09 Posted on Tuesday, December 29, 2009 - 08:26 am: just wondering if anyone as the code for renault sceinic radio model no22dc258/62p prod no fd0002040008503 any help would be great ============================================= Insufficient information Please quote the 14 character Serial Number beginning with RN++++++++++++ and the Security Number ( eg..TOA123 or TA123 or A123 ) Any doubt then quote EVERYTHING |
New member Username: DidlyrooPost Number: 2 Registered: Dec-09 | sorry about that new to this the number on the side is rn258f20008503 security number t0s418 |
Gold Member Username: RegroosterPost Number: 2727 Registered: Aug-08 | rob New member Username: Didlyroo Post Number: 2 Registered: Dec-09 Posted on Wednesday, December 30, 2009 - 09:12 am: sorry about that new to this the number on the side is rn258f20008503 security number t0s418 =============================================== Try code 7541 ------------------------------------------------------ PayPal donations to my Code Calculator Software Fund are always welcome Donate link here www.bit.ly/donate4code Every penny ,euro or cent donated is going towards further Code Calculator Software allowing me to expand this free decoding help on this forum |
New member Username: PschuldPost Number: 2 Registered: Jan-10 | Hi, please can you give me the code for my Renault Scenic Tuner List radio? The Model No is: RENRDW131-10 K215 Security RNRD0340210066 Product No: FD0604400210066 there is an additional bar code: 8200300858TK215 and two boxes below: 8200 300 858 --B Thanks! Paul |
Gold Member Username: RegroosterPost Number: 2751 Registered: Aug-08 | Duplicate request...Already answered Please do not post the SAME request in two different threads on this forum ! |
New member Username: LewrotTonbridge, Kent England Post Number: 1 Registered: Jan-10 | Hi There, Would you be able to supply me with a code for my renault scenic radio please, i have just replaced the battery and forgot about the radio code rn/ 22dc593/62l 902221593624 m/ch 151779 barcode 77004135b7 q464 Do you need any more than this? thanks in advance Lew |
Gold Member Username: RegroosterPost Number: 2790 Registered: Aug-08 | Lew Rotherham New member Username: Lewrot Tonbridge, Kent England Post Number: 1 Registered: Jan-10 Posted on Tuesday, January 05, 2010 - 08:04 am: Hi There, Would you be able to supply me with a code for my renault scenic radio please, i have just replaced the battery and forgot about the radio code rn/ 22dc593/62l 902221593624 m/ch 151779 barcode 77004135b7 q464 Do you need any more than this? thanks in advance ================================================== Try code 9569 PayPal donations to my Code Calculator Software Fund are always most welcome Donate link here http://bit.ly/donate4code Every penny ,euro or cent donated is going towards further Code Calculator Software allowing me to expand this free decoding help on this forum |
New member Username: LewrotTonbridge, Kent England Post Number: 2 Registered: Jan-10 | Worked a treat, many thanks Lew |
New member Username: Antonio81Post Number: 1 Registered: Jan-10 | Hi, I've need the code for my stereo "tuner list" of the Renault Megane II (08/2003), I've changed the battery and I don't know there isn't the code in to manual service book...!!!! Help Me..Help me....I don't know any time to go to Renault service long 100 KM from my house.....HELP ME.. MOD N° 22DC277/62T TOC243 RN277F20001336 PROD N° FD0002240001336 BAR CODE 8200074336TC243 THANKS...CAN YOU SEND ME THE ADDRESS PAYPAL FOR DONATION? |
Gold Member Username: RegroosterPost Number: 2827 Registered: Aug-08 | Antonio New member Username: Antonio81 Post Number: 1 Registered: Jan-10 Posted on Friday, January 08, 2010 - 05:05 pm: Hi, I've need the code for my stereo "tuner list" of the Renault Megane II (08/2003), I've changed the battery and I don't know there isn't the code in to manual service book...!!!! Help Me..Help me....I don't know any time to go to Renault service long 100 KM from my house.....HELP ME.. MOD N° 22DC277/62T TOC243 RN277F20001336 PROD N° FD0002240001336 BAR CODE 8200074336TC243 ================================================== Try code 1755 PayPal donations to my Code Calculator Software Fund are always most welcome Donate link here http://bit.ly/donate4code Every penny ,euro or cent donated is going towards further Code Calculator Software allowing me to expand this free decoding help on this forum |
New member Username: ThomassonePost Number: 2 Registered: Jan-10 | No: 22dc259/62p RN259F10209652 Tom 953 FD0401020209652 7700434424TN953 PLEASE HELP ME |
Gold Member Username: RegroosterPost Number: 2847 Registered: Aug-08 | thomass.one New member Username: Thomassone Post Number: 2 Registered: Jan-10 Posted on Saturday, January 09, 2010 - 03:10 pm: No: 22dc259/62p RN259F10209652 Tom 953 FD0401020209652 7700434424TN953 -------------------------------------------------------------------------------- --- Please check all the letters and numbers again as they are not accurate. .Especially Tom 953 and 7700434424TN953 |
New member Username: RtscfcPost Number: 1 Registered: Jan-10 | Hi is there any chance you could help me ive looked everywhere without succes for a code for my renault scenic 02 stereo the codes are model number 22DC278/62P TOI730 RN278F20058139 PRODUCT NUMBER FD0002150058139 hope you can help thanks in advance |
Gold Member Username: RegroosterPost Number: 2855 Registered: Aug-08 | rtscfc New member Username: Rtscfc Post Number: 1 Registered: Jan-10 Posted on Sunday, January 10, 2010 - 12:35 pm: Hi is there any chance you could help me ive looked everywhere without succes for a code for my renault scenic 02 stereo the codes are model number 22DC278/62P TOI730 RN278F20058139 PRODUCT NUMBER FD0002150058139 hope you can help thanks in advance -------------------------------------------------------------------------------- Try code 0591 PayPal donations to my Code Calculator Software Fund are always most welcome Donate link here http://bit.ly/donate4code Every penny ,euro or cent donated is going towards further Code Calculator Software allowing me to expand this free decoding help on this forum |
New member Username: RtscfcPost Number: 3 Registered: Jan-10 | 0591 isnt working thanks for your response... |
Gold Member Username: RegroosterPost Number: 2857 Registered: Aug-08 | Sorry ...my mistake try 8591 |
New member Username: User0815Post Number: 1 Registered: Jan-10 | Hello to all Members, Hello Reg Rooster, can you please help me with the code for the following "tuner list": RENRDW131-10 T0D033 RNRD0330006945 FD0003160006945 8200300858TD033 Thanks! |
Gold Member Username: RegroosterPost Number: 2859 Registered: Aug-08 | user0815 New member Username: User0815 Post Number: 1 Registered: Jan-10 Posted on Sunday, January 10, 2010 - 04:36 pm: Hello to all Members, Hello Reg Rooster, can you please help me with the code for the following "tuner list": RENRDW131-10 T0D033 RNRD0330006945 FD0003160006945 8200300858TD033 ------------------------------------------------------------------------------ Try code 1914 PayPal donations to my Code Calculator Software Fund are always most welcome Donate link here http://bit.ly/donate4code Every penny ,euro or cent donated is going towards further Code Calculator Software allowing me to expand this free decoding help on this forum |
New member Username: MickpmPost Number: 1 Registered: Jan-10 | Afternoon all, yet another Newbie in search of a code for a Renault/Phillips "Tuner List" unit. Code sticker in the book claims the code is 6651 but it refuses to have any of it. Can anyone help with the following details: Model No: 22DC278/62B, Prod No: FD0302370278772 Additional numers are: RN278F20278772 & TOZ392 Many thanks in advance, Mick P |
Gold Member Username: RegroosterPost Number: 2979 Registered: Aug-08 | Mick P New member Username: Mickpm Post Number: 1 Registered: Jan-10 Posted on Friday, January 22, 2010 - 07:52 am: Afternoon all, yet another Newbie in search of a code for a Renault/Phillips "Tuner List" unit. Code sticker in the book claims the code is 6651 but it refuses to have any of it. Can anyone help with the following details: Model No: 22DC278/62B, Prod No: FD0302370278772 Additional numers are: RN278F20278772 & TOZ392 ================================================== Try code 0651 PayPal donations to my Code Calculator Software Fund are always most welcome Every penny ,euro or cent donated is going towards further Code Calculator Software allowing me to expand this free decoding help on this forum |
New member Username: Erik_caPost Number: 1 Registered: Jan-10 | Hi. Can you help. I have Renault Scenic II. Need radio code. (CArminat) Type Navigation Model No: BE 7409 Serial No: 35002507 thanx a lot |
Bronze Member Username: AmiloPost Number: 36 Registered: Jul-09 | Answer for Erik RENAULT CODES visit www.ukbookshelf.co.uk for your Becker code |
New member Username: Erik_caPost Number: 2 Registered: Jan-10 | what is it becker? |
New member Username: DecavisionPost Number: 1 Registered: Feb-10 | Hey, I need a code for Renault Scenic II -05, I think it's a philips player... RENRDWT31-10 J1199 SECURITY RNRD034017000 8200300858TJ199 8200 300 855 --B, thanks! Embarassed |
Bronze Member Username: Misha88Kiev Post Number: 43 Registered: Feb-10 | Hi Mikko Maatta! Your code on radio 7703. you will reveal to me about the results of verification. write to me on magnitola2010@rambler.ru |
New member Username: DecavisionPost Number: 2 Registered: Feb-10 | Worked! |
New member Username: Afg77alexPost Number: 1 Registered: Mar-10 | hi i really need the code number of stereo tuner list of my car its a renault scenic 2004 an the serial number 3BNJA2HC94K015261 THANK YOU VERY MUCH |
Silver Member Username: DecodePOLAND Post Number: 553 Registered: Jan-09 | 5 euro for code payable via paypal radiocodeservice@gmail.com |
Bronze Member Username: Misha88Kiev Post Number: 62 Registered: Feb-10 | Hello si! eoiiaoey not complete! you will look other numbers. or write to me on magnitola2010@rambler.ru I will send an example that is needed. |
New member Username: SceniciiPost Number: 1 Registered: Mar-10 | Hi, I need a radio code for a 2002 Renault Scenic with a built in radio. Where do you get the serial numbers and model numbers that everyone else quotes for these built in radios? Chassis number VF1JA130220609033 Engine number F4RE747C008857 Any help much appreciated. I wonder iff these "security measures" have ever pissed of anyone other than the owner of the car. Thanks in advance |
Silver Member Username: Hay88Post Number: 197 Registered: Mar-10 | hi secnicll your have to remove your radio there are two small holes on each side put a very small screwdriver in hole and push outwards sideways. and pull the radio forward carefully ,then post your numbers/letters below barcode like 77xxxxxxxxxtt123 or like Q123-security then i can help you. please dont leave letter and numbers off the end cause thats what is needed, |
New member Username: SceniciiPost Number: 2 Registered: Mar-10 | Thanks for the help. The Model number is 22DC278/62P under neath that is T0S084 then RN278F20013742 Product number is FD0002030013742 and underneath that is 8200152346TS084 thanks again |
Gold Member Username: RegroosterPost Number: 3457 Registered: Aug-08 | scenicII New member Username: Scenicii Post Number: 2 Registered: Mar-10 Posted on Tuesday, March 23, 2010 - 12:36 am: Edit Post Thanks for the help. The Model number is 22DC278/62P under neath that is T0S084 then RN278F20013742 Product number is FD0002030013742 and underneath that is 8200152346TS084 ========================================== Try code 7984 |
New member Username: SavehomeLazPoland Post Number: 1 Registered: Mar-10 | Hello! I need code for Renault megane 2000 BUILT-IN car radio Model. no: RN279F20318704 T0R571 Prod. no: FD0202260318704 8200002607TR571 8200002607 --C |
Gold Member Username: RegroosterPost Number: 3475 Registered: Aug-08 | savehome New member Username: Savehome Laz Poland Post Number: 1 Registered: Mar-10 Posted on Saturday, March 27, 2010 - 11:56 am: Edit Post Hello! I need code for Renault megane 2000 BUILT-IN car radio Model. no: RN279F20318704 T0R571 Prod. no: FD0202260318704 8200002607TR571 8200002607 --C -------------------------------------------------------------------------------- - Try code 8422 |
New member Username: Vio1960Post Number: 1 Registered: Apr-10 | Hi There, Would you be able to supply me a code key for my Renault Scenic II (2007) radio? I have just made a "big" mistake - I accidentally disconnected the radio set and the former owner has not provided me the service card RNRDAP70303678 RENRDW330-19 F978 SECURITY barcode 8200607918T thank you in advance! |
Bronze Member Username: Misha88Kiev Post Number: 82 Registered: Feb-10 | your code of radio 2395 write to me on magnitola2010@rambler.ru after his verification |
New member Username: Vio1960Post Number: 2 Registered: Apr-10 | it works! thank you very much! |
