Saxo Clarion code needed please !
Username: Stevieb
Hi, can any one out there help me find this radio code please
Serial No CL0402Y0438926
Model No PU-2294B (D)
Many Thanks.
Username: Misha88
Kiev
Post Number: 75
Hello! Information for being code not complete
write to me on magnitola2010@rambler.ru
all other numbers from a radio-recorder
also bar code
Username: Regrooster
Post Number: 3453
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
Username: Stevieb
Ok, I have the radio in front of me, there is no C7000000++++ numbers on there, thanks for your help.
Username: Hoody99
any chance of a code for - GM0500V9224438 ?
cheers
Post Number: 3461
Duplicate request!
Multi-posted requests are ignored on this forum as they are both timewasting and annoying to the volunteers who read and answer these code calculation requests..
If you are that impatient for your code then try an online Decode Service who will supply your code by return.
