BMW radio code
Username: Doogle
Hi all.
My battery went dead, and yes, I need the code...
But I never thought it'd be this much of a pain in the a**e to find! All help would be really appreciated as I've not had tunes in the car for ages.
Thanks
Chris
Username: Doogle
And obviously quite sleepy....
Numbers!!
AL 003E W 0673551 C
Thx
Username: Hay88
Post Number: 134
hi chrisq is that all numbers and letters you have. i can do some but most have a BPxxxxxxxxxxxx number and 7 xxx xxx xxx
Username: Doogle
These are the numbers off the radio card in the documents. I think i'll have to remove it to get the numbers off the radio itself
Username: Hay88
Post Number: 136
yes i think you need to.
