Siemens VDO unlock code please?
Username: Pudlane
Hello all
Please could you let me know the radio unlock code for my Vauxhall Corsa 2004.
The stereo is a Siemens VDO
Number 330886636
No. 13 122 932
Type CDR2005(e)
Serial Number - GM020543435583
If you need any more information, please do not hesitate to ask.
Thank you in advance for your great service.
Kind regards
Chris
Username: Regrooster
Post Number: 3377
Unfortunately the majority of SIEMENS/VDO codes (including your CDR2005) will NOT be available for free (or cheap) from anywhere on the Internet as access is required to the original factory database...which is not commercially available..
Try your Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are normally the cheapest option) who will connect it to a laptop to read/recode the memory chip (EEPROM)
Username: Pudlane
Thank you for the prompt response Reg Rooster.
I will try my local place if there is no way round hooking it to their laptops.
Thanks again
Chris
