Bronze Member Username: Jonez788Post Number: 13 Registered: Jun-04 | Box: http://www.cardomain.com/item/RTE32312 Amp: Kicker KX 800.2 Running at 2 X 400watts @ 2 Ohms. Subs: 2 Kicker Comp VR 12" 400 watts RMS Phoenix Digital 4 Gauge wiring kit. $538.40 Total w/shipping. |
ThatGuyYouKnow Unregistered guest | I dont like the fact of that sub specs on sealed enclosers 1.00 - 4.60 cu ft, I have no idea what they would sound in taht 1.75 cu ft box, but its in the specs but i dont know what it would sound like |
Bronze Member Username: Jonez788Post Number: 14 Registered: Jun-04 | Well, I could get a smaller one... |
Bronze Member Username: Jonez788Post Number: 15 Registered: Jun-04 | Should I go with the 1.75 cubic feet particle board one or a 1.21 MDF one? |
Bronze Member Username: Jonez788Post Number: 16 Registered: Jun-04 | Uggh, sorry or a 1.35 5/8 MDF one. |
ThatGuyYouKnow Unregistered guest | Well i dont know how the box with affect the subs performance either the smaller the box the tighter the bass and the bigger the box the louder the bass, im probly wrong cuz i have no idea but im waiting for a reply from Glass wolf or Jon or atleast JayJ... |
Silver Member Username: Sploosh56Post Number: 264 Registered: May-04 | That box will do for now for the subs. In the furture get a box that is better built. But for now that box will do. Godd choice on the subs and amp. That will sound nice and will be pretty loud. |
Bronze Member Username: Jonez788Post Number: 17 Registered: Jun-04 | So stick with the 1.75 cubic foot one? It is CHEAP and after the subs and amp it put me down on the budget left over;) Glass? Any input? |
Silver Member Username: Sploosh56Post Number: 265 Registered: May-04 | Yea stick with that enclosure. |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 3664 Registered: Dec-03 | my recommendation: two 4 ohm (dual 2 ohm coils per sub) CompVR 12" subs 1 Kicker KX600.1 amp (the subs are rated for 300w each. good match) knukonceptz.com 4ga kit $30 box: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39777&item=5706903932&rd= 1&ssPageName=WDVW you want about 2cu ft per sub ported, or closer to 1.3-1.5cu ft per sub sealed. |
ThatGuyYouKnow Unregistered guest | go with the Knukonceptz wire I did, ty glasswolf that was like 6months ago and do'n great. |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 3668 Registered: Dec-03 | great stuff for the price. There's fancier stuff out there if you want to pay $100 for each cable, but for folks on a working man's budget, that site is great. glad it's workin' for ya. |
Bronze Member Username: Jonez788Post Number: 18 Registered: Jun-04 | Glass, aren't the subs 400 watts RMS? |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 3714 Registered: Dec-03 | ahh, somebody went and put the 3 next to the 4 on my keyboard. those b*stards |
Bronze Member Username: Jonez788Post Number: 23 Registered: Jun-04 | Haha, you ARE a funny man![]() |
