Clarion PU 9971 A Radio Code
Username: S_norris
Can someone help me by finding the radio code for a:
Clarion
Model: PU 9971 A
Serial No: CL0267X0204386
Other numbers found on the label are:
96 233537 ZL
286-8497-1? (last letter has been defaced)
Peugeot have already given us a code but it doesnt work.
Radio is not locked.
Thanks in advance
Username: Regrooster
Post Number: 3237
Model: PU 9971 A does not use a memory chip for a code but uses a hardwired system and will require specialist attention.
Try emailing
restoredclassic@aol.com
to see if they can help
Mention this forum
Username: Xoman
WatfordUnited Kingdom
The documentation for the car says the radio ought to be
28185 9U10A / PN-3001P
serial number 0022606
pin code 2375.
But this pin code doesn't work.
Upon removing the radio it has numbers:
28185 9020A
serial number PN-3000PA 0011825
and in the chassis has these numbers marked:
CL081870011825
Can a code be provide for ths Clarion CD / Radio?
Thanks in advance
Post Number: 3271
Alex
Username: Xoman
Watford
United Kingdom
Registered: Mar-10 Posted on Wednesday, March 03, 2010 - 10:10 am:
pin code 2375.
28185 9020A
CL081870011825
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
