Clarion Radio code
Username: Xoman
WatfordUnited Kingdom
The documentation for the car says the radio ought to be
28185 9U10A / PN-3001P
serial number 0022606
pin code 2375.
But this pin code doesn't work.
Upon removing the radio it has numbers:
28185 9020A
serial number PN-3000PA 0011825
and in the chassis of the radio has these numbers marked:
CL081870011825
Can a code be provide for ths Clarion CD / Radio?
Thanks in advance
Username: Regrooster
Post Number: 3272
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
