Radio code for citroen xantia
Username: T6ivo
Estonia
I changed battery and now i dont have radio code anymore. Can somebody help me?
Radio is original BLAUPUNKT.
Blaupunkt (9613345880)
citroen PH1/ D
7642490394
BP2490P5756302
These are numbers which i found .
I hope somebody can help me.
Thanks!
Username: Decode
POLAND
Post Number: 491
T6ivo--- >4277 or 0277 or 0283
Username: T6ivo
Estonia
Thanks but i still have problem with this radio.
I allready had 4277 but somehow it didnt worked.
I tryed others which you gave me but these just wont work too .
What should i do? Are there more codes or something?
Username: Misha88
Post Number: 9
coded 4884
write to me about a result
Username: Regrooster
Post Number: 3187
This is a CITROEN Blaupunkt and the code is definitely 4277
