Bronze Member Username: Jr96ejLas Vegas, NV Post Number: 25 Registered: Feb-09 | is 140 amps at idle good enough for a aq2200 ? the alt im thinking about getting is the dcpower gm 190 amp oem alt they say it puts out 140 amps at idle. |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 13088 Registered: Jun-04 | If you want all you can get out of the amp get as close to 200 amp idle you can. To me 140 isnt quite enough. |
Bronze Member Username: Jr96ejLas Vegas, NV Post Number: 26 Registered: Feb-09 | hmm well i mean the next step up which is 200 dollars more is only 15 more amps at idle is that really gonna make that much difference ? |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 21909 Registered: Jun-06 | Depends on how you play your system. Idle power can play a big part in stop light show offs, unless you have a mad battery bank.![]() |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 13102 Registered: Jun-04 | Honestly I wouldnt pay 200 more for 15 amps. Who are you looking through? |
Bronze Member Username: Jr96ejLas Vegas, NV Post Number: 27 Registered: Feb-09 | well the choices for my vehicle from dc power website are as follows '96-'06 GM Truck & SUV AD 190 AMP OEM series alternator Email to a Friend Be the first to review this product Sign up for price alert Availability: In stock. $329.00 Add Items to Cart Qty: Add to Cart OR * Add to Wishlist * | Add to Compare Quick Overview The best value DC Power Alternator A Direct Bolt on OEM fit! Super high performance at idle, 140 Amps. Built from 100% BRAND-NEW USA made parts!! Comes standard with our custom hard anodized billet aluminum pulley for MAXIMUM output at idle! choice 2 '96-'06 GM Truck/SUV AD 230 Amp SP series alternator Email to a Friend Be the first to review this product Sign up for price alert Availability: In stock. $489.00 Add Items to Cart Qty: Add to Cart OR * Add to Wishlist * | Add to Compare Quick Overview * The best performing DC Power Alternator * A Direct Bolt on OEM fit! * Super high performance at idle, 160 Amps. * Built from 100% BRAND-NEW USA made parts! * Comes standard with our custom hard anodized billet aluminum pulley for MAXIMUM output at idle! and last and most expensive 96-'06 GM Truck/SUV AD 270 Amp SP series alternator Email to a Friend Be the first to review this product Sign up for price alert Availability: In stock. $549.00 Add Items to Cart Qty: Add to Cart OR * Add to Wishlist * | Add to Compare Quick Overview * The best performing DC Power Alternator! * A Direct Bolt on OEM fit! * 180 amps at IDLE! * Built from 100% BRAND-NEW USA made parts! * Comes standard with our custom hard anodized billet aluminum pulley for MAXIMUM output at idle! * One Year warranty since im only going to sick with the aq2200 no plans for upgrades on the vehicle running 2 yellow tops that i already have i just want the cheapest one that will work for me as i dont need headroom its just a daily vehicle |
Bronze Member Username: Jr96ejLas Vegas, NV Post Number: 29 Registered: Feb-09 | also keep in mind that i dont really go down the road full tilt i live in vegas strict sound laws here 50 ft and its a fine so im not one for stop light showdowns .. i just want it to function with no issues really |
Gold Member Username: Kingandsons07Www.kingmobi... Lincoln,NE Post Number: 1196 Registered: Aug-08 | look here man http://www.db-starter-alternator.com/Alternators/High%20Output%20and%201-Wire/Ch evy%20and%20GMC%20Trucks/ |
Bronze Member Username: Jr96ejLas Vegas, NV Post Number: 30 Registered: Feb-09 | Hmm sounds pretty decent they have one that reaches 250 at 1200 rpm and does 125 at idle. Anyone have any feedback about this company? I've never really heard much about them here before, always mechman , dc and ohio gen. If you guys think they are worth it ill get the db its only $270. |
Bronze Member Username: Jr96ejLas Vegas, NV Post Number: 31 Registered: Feb-09 | edit. |
Gold Member Username: Kingandsons07Www.kingmobi... Lincoln,NE Post Number: 1197 Registered: Aug-08 | yeah i think Mark on here runs one and does a great job! he had 4 or 5 MechMan alts that feep failing so he got one of these. IMOH i'd only get DB or Ohio Gen |
Gold Member Username: Hittin1TEAM REVOLUTION, La. Lake Charles... Post Number: 4266 Registered: May-07 | c'mon quentin... I'm running DC Power's big dog. 200 idle amps. I have had zoro issues. will not be changing Alt coompanies anytime soon. |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10916 Registered: Jul-06 | Db is among the best in alternators and also have great prices. I've installed several including my own and no issue. |
Gold Member Username: BernymacPhnom PenhCambodia Post Number: 4786 Registered: Sep-04 | Are you guys talking about this DC power? http://www.dcpowerinc.com/ |
Gold Member Username: Kingandsons07Www.kingmobi... Lincoln,NE Post Number: 1198 Registered: Aug-08 | my bad mark lol DC ![]() i was so close lol |
Bronze Member Username: Jr96ejLas Vegas, NV Post Number: 32 Registered: Feb-09 | well guys thanks for the help i think im just gonna get the db 250 amp alt and call it day =D |
Gold Member Username: Basebalz13Moneta, Va Usa Post Number: 2008 Registered: Aug-07 | Mechman has had a problem or two, so has DC power http://www.caraudio.com/forum/showthread.php/460682-DC-alternators-CS?p=6925484 |
