Help please???
Username: Henrythreeyahoocom
i have an l7 kicker 15" dual 4ohm and a 850.2 kicker amp.i am in desperate need in help with how to wire them??
Username: Hittin1
TEAM REVOLUTION, La. Lake Charles...
Post Number: 4284
that is the wrong voice coil configuration fior that amp.
you need anp amp that is ~1000wrms at 2 ohm. If you are gonna run a 2channel amp make sure it is 2ohm stable (bridged)
Username: Simple_smith
Lapeer, Michigan United States
Post Number: 221
go to the rockford fosgate website and go to the wiring wizard (Its magical)
Username: Bookeeper
Louisiana
Post Number: 43
i would get 1000 watts rms mono amp what kind thats up to that way you dont have to worry about how to wire it but i got bridegable amp thats 2 ohm stable giving you 1000 watts wud be good
Username: Skdooley
Roanoke, VA Usa
Post Number: 229
Most 2 channel amps are going to want to run at a 4 ohm load bridged to one channel. That sub will either run at a 2 ohm load or 8 ohm load. You'll either need a dual 2 ohm sub or a 2 ohm stable amp.
