New member Username: Rman89Post Number: 1 Registered: May-09 | i have a box thats 9 by 15 by 22 and i was wondering what size aero port would get the box tuned to 35hz |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 6683 Registered: Nov-05 | what size aero port. |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 6684 Registered: Nov-05 | .. whoops.. 4" or 6" .. i'd assume 4" but without knowing which diameter you choose we really can't help |
New member Username: Rman89Post Number: 2 Registered: May-09 | 4" diameter sorry about the misunderstanding |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 6685 Registered: Nov-05 | what do you plan on running, that box is very small.. maybe large enough for a single ported 8" |
New member Username: Rman89Post Number: 3 Registered: May-09 | So I'm just looking for what length I would need |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 6686 Registered: Nov-05 | if your porting a sealed enclosure.. itll sound horrible i'd rather give you specs to build a new box than give you specs to port a sealed box.. its just not worth the trouble |
New member Username: Rman89Post Number: 4 Registered: May-09 | the box is sealed but its too big for the sub so im just messing around with it |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 6690 Registered: Nov-05 | what is the sub? |
New member Username: Rman89Post Number: 5 Registered: May-09 | alpine type r 10 |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 6693 Registered: Nov-05 | that box is the correct volume for that sub sealed. |
Gold Member Username: DeadrabitMarionville, MO Post Number: 1831 Registered: Jun-07 | use this http://www.carstereo.com/help/Articles.cfm?id=31 |
New member Username: Rman89Post Number: 6 Registered: May-09 | thanks man i appreciate the help |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 6694 Registered: Nov-05 | build a new box. |
New member Username: Rman89Post Number: 7 Registered: May-09 | Modified the box sounds amazing thanks dBlk |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 6703 Registered: Nov-05 | lol.. ![]() imagine a box build to actual specs |
