New member Username: MikerandPost Number: 1 Registered: May-09 | Sup guys, I just got a new car, and I'm interested in putting some subwoofers in so I decided to join these forums cuz I need some help... -I have a 1998 Acura Integra LS. -I want to spend about $300. -I listen to Hip Hop/Rap -I want it to have hard hitting bass, but at the same time good quality.... I don't know if that is too much to ask for, but maybe u guys could give me some advice.... Thanks ![]() |
Bronze Member Username: Bachman101Post Number: 28 Registered: May-09 | For subs go with either 1 15" or 1 12" FI BL depending on the space in your trunk. They'd hit hard as sh!t in the right tuned ported enclosure. |
Gold Member Username: CtmikeCt. Post Number: 6707 Registered: Feb-06 | $300 just for the subs? spencer, how'd you like the bls'? been thinking of getting one but haven't heard one. what would you compare it to? |
New member Username: MikerandPost Number: 2 Registered: May-09 | nah, like 300$ for the whole system (subs, amp)...i might go up to 350$. |
Silver Member Username: Armykyle1Ms Us Post Number: 580 Registered: Dec-08 | WOW, BALLIN, SAVE UP YOUR MONEY AND BUY SOMETHING WORTH BUYING |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 6624 Registered: Nov-05 | Your not going to get anything with $350 unless you shop at a flea market and buy refurb Well you could, but it would honestly be a waste of money since in the end you'd end up getting something better later down the line |
Gold Member Username: SomedonniedudeIllinois Braaap MX Post Number: 2621 Registered: May-07 | http://www.audioque.com/aq/SDC2_5_Series.htm Audioque SDC2.5 RE SE on ebay (I personally like the sq of these) Amp...anything that can do 600w rms. If you get a dual 4 ohm subwoofer you need 600w rms @ 2 ohm. If you get dual 2 ohm, get an amp that does 600w rms @ either 1 or 4 ohms. |
Gold Member Username: SomedonniedudeIllinois Braaap MX Post Number: 2622 Registered: May-07 | If those are too much, get a Type R off of ebay and give it 600w as well. Remember, the box you put the sub in is very important. If you need quality budget wiring...http://knukonceptz.com/. Grab some 4ga so you have room to upgrade in the future. |
Bronze Member Username: Bachman101Post Number: 30 Registered: May-09 | yeah i second donnie, my type R was awesome and nobody complains. IMO the best sub in that price range. ctmike, Ive only heard them once at a show last year. some guy had two 15" in an explorer and it straight pounded, it seemed to be a great spl sub and SQ was takin into consideration but i think he setup was more spl. Though to answer your question i dont have the greatest idea because im still young and i havent been able to test, workwith, or experience too many brands. But for sure 1 15" would pound harder than a 12W7, or both my type R's. Though i think mine hit the highs better of course. |
New member Username: MikerandPost Number: 3 Registered: May-09 | K thanks alot guys, Do u guys think I should go for 2 10" subs or 1 12". |
