RE MT or SX?
Username: Jordon32990
Post Number: 59
A buddy of mine recently bought a pair of 18" RE's that he claimed were MT series.
When he showed them to me, my first thought was that there was no way that was an MT.
He bought them used, and was simply told by the seller they were the MT.
Is it possibly an old model MT?
I thought it looked like the SX series.
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 6527
looks like an SX to me
mts did not do the inverted cap
check the motor for a pole vent.. if there is not one its an mt
Post Number: 60
Alright, I'll check.
If its an MT, its unlike any I have ever seen...
Username: Loc_out
SoCal
Post Number: 2870
Motor looks too small to be a MT.
Post Number: 61
It has a pole vent, so it is an SX like I thought.
How good are the SX? I offered to buy one off of him.
Just wanting to hear a couple reviews...
Username: Loc_out
SoCal
Post Number: 2877
They are solid sub's you won't need much power to get them moving. 1000-1500 will do vs the MT that will take 2500-3000.
Post Number: 62
If I do end up with the SX I will have to build a blow through box for my MJ. It has a tonnea cover so it'd be safe from the weather and/or theives.
Box suggestions?
Username: Frkkevin
Post Number: 6531
hope he did not pay too much for those lol
Post Number: 63
$550 I believe...
Still not a bad price.
Username: Frkkevin
Post Number: 6534
that is actually pretty bad for a pair of SX 18"s
Post Number: 64
Really? The only place I could find them sold em at $450 per sub...
http://www.dealercostcaraudio.com/reaudiosx18.aspx
Post Number: 65
Well, not the "only," but the cheapest
Username: Frkkevin
Post Number: 6535
i'd have to look through my order catalog but i used to be able to get those through my wholesaler cheap.. like barely over $200ea bnib SX 18s
used i would not pay more than $225 shipped.. those look a bit scuffed
$550 is not horrible.. prolly coulda saved $50-$75 which is really just pocket change
long as he likes em.. or you do :-)
Post Number: 66
They look better than the pic shows. The camera off the cell gets distorted when transfering to the PC via email.
$200, wow... Need to get my hands on one of those catalogs...lol
Username: Frkkevin
Post Number: 6536
wholesaler stopped selling RE Audio/US Amps just recently.. the one i went through :-(
Post Number: 67
Man thats a bummer.
I got a question, what kind of shallow mount subs can you get me for cheap that can handle 1000 rms.
I plan on getting two SI Mags when I can find a buyer for my 13W7. But if I can find something good for less I'm down for that.
Username: Frkkevin
Post Number: 6537
how'd you got from shallow mount to si mags in one paragraph?
Post Number: 68
The new V4 mags are like 5 1/2" deep. I need something that can fit in my truck. I am fairly confident the V4's will. But thats $500 for a pair.
Just curious if you have access to some less costly quality shallow mount subs.
Username: Frkkevin
Post Number: 6538
think the only company they carry that has shallow mount is pioneer
i'd just spend money on the v4s, you'd be much happier
$500 for a quality pair of subs that you probably will not upgrade from is worth spending half as much on something you may not be happy with and replace
Post Number: 69
Not a big Pioneer Sub/Amp guy by any means...lol
I like some of their head units, I actually have one in my Manche, but I'm about to replace it with an Alpine soon...
I have some pictures of the truck here. I think I could build a box to fit. Probably do two individual sealed boxes behind driver and passenger seats. I would try center console, but theres not a whole lot of room there anyways...
What do you think?
Username: Frkkevin
Post Number: 6541
looks like you can do two 12s.. just build it to use the entire space up to the window line
Post Number: 70
I could do that, but then I would have to find a new place to mount the amps.
I have two very scratch sensitive black JL's.
Perhaps I could go with the individual sealed boxes, built to the window line, with enough space between the boxes for the amps?
Post Number: 74
Well... Do you still think I can fit those 12's?
i think I can, I have about 1 ft wide on either side.
If I build the boxes to the window line I should have enough air space for the Mags I'd think.
