New member Username: MicheintzPost Number: 1 Registered: Mar-09 | Hi I need the Code for my Renault Megane Radio. It is a Model "Tuner List" from 2002 Model No: RENRDW132-10 V938 Security Prod No: FD0404190076791 And i Find this Nummer on the right Site: 8200300859TV938 And under There: 8200300859 --B Thank you for your Help Mic |
New member Username: MicheintzPost Number: 2 Registered: Mar-09 | I forgot the Company: The radio is from Philips Thank's Michael |
Bronze Member Username: DecodePost Number: 47 Registered: Jan-09 | Michael Heintz ------> code 4099 --------------------- If this code has helped you in anyway - and you want to say thanks ,like beer donation ![]() this is my paypal ( www.paypal.com ) e mail: lynx222@o2.pl |
New member Username: MicheintzPost Number: 3 Registered: Mar-09 | The Code don't works with my Radio !!! |
Bronze Member Username: DecodePost Number: 48 Registered: Jan-09 | 8200300859TV938---> it's correct number?? check it |
New member Username: MicheintzPost Number: 4 Registered: Mar-09 | The Number is Correct !! But I don't know, theres the Serial-Number ?!?! Thanks Michael |
Bronze Member Username: DecodePost Number: 49 Registered: Jan-09 | for V938---> code is 4099 ..must have been recoded..or you are not entering it correctly.. |
New member Username: MicheintzPost Number: 5 Registered: Mar-09 | I don't know if the radio-Code is changed I have bought the Radio at Ebay S*H*I*T*.............. but thanks for your help !!! MICHAEL |
Silver Member Username: RegroosterPost Number: 768 Registered: Aug-08 | A longshot...but try code 5092 |
Bronze Member Username: DecodePost Number: 50 Registered: Jan-09 | yes maybe it's U938 and then 5092 is good code |
New member Username: MicheintzPost Number: 6 Registered: Mar-09 | Is not the correct Code !! The Renault Support says : He need the Number of the Car, to gernerate the Radio Code ! This is important for you ? **** Michael |
New member Username: MicheintzPost Number: 7 Registered: Mar-09 | Hi @all I do not want more !!!!! I send the radio back to the Ebayer and want my money back !!! Many thanks for your help Michael |
